Hi Winaje, I am currently undergoing exactly the same in my D1. I have a SC-80 under the bonnet of the D1. I have a Fullriver 105AH battery (in the camper trailer) and a Fullriver 55AH (in the rear of the Rover) both powering an Evakool 45L fridge. Issues I have found are: D1 vehicle alternator only puts out 13.7Vdc. I have been informed that the AGM batteries need 14.7Vdc to charge to maximum capacity.
My solution (just purchased today) is CTEK MXS15 battery charger to charge both batteries from 240Vac when at home or when 240Vac power is available, i.e. generator, campground etc.
Future plan is to install a CTEK D250S Dual in the Disco to fully charge both batteries when the vehicle is running and to provide capability to connect a solar panel to the same charger. No solar regulator is required with this charger.
On the issue of diodes I do not believe they will be required as the SC-80 isolates the start battery from the Aux. battery. The solar regulator you get and the 240Vac battery charger you get should have inbuilt protection to prevent back feeding. I would, however, install circuit breakers on each of the feeds to the battery so that if you have a short in any of the feeds you have some protection. (This is only my opinion though).
Warren
Currently Landroverless - Still interested
Formerly: 2003 D2a Update TD5 Auto. Platinum edition. ARB Bar, 36" LED light bar, cargo barrier, dual batteries.
