Thread: D3 Trailer LED light Pulse and AUX power help needed please
    Sep 2011
    SE Melbourne, AU
    Unhappy D3 Trailer LED light Pulse and AUX power help needed please
    Hi All,
    'have a jayco with LED lights and have the light pulse issue - Ive spotted Pulse Busta at $363 and LEDTow Connect at $239 Delivered to plug in line of the connecting cable to resolve...
    Any other suggestions or products out there I should consider? I am not an Auto electrical so want a plug in solution.
    Next up the "Spare" or Auxiliary white capped left tow pack power outlet... is there a cable I can buy with the round socket on one and then a small anderson plug on the other - or what pins are + and - so I can buy plugs and wire and initiate my electrical skills! this is to run the Fridge in the Jayco whilst in transit from the car battery.
    all help greatly appreciated - feel free to point me to previous links or repost in best suited forum thread.
    Cheers.
    NSW SW Slopes
    Did you find the info or are you still needing to know?
    Oct 2011
    Apsley
    flashing leds
    I think the best solution would be take it to an auto sparky ,I have a similar problem with my fl2 in that my camper has normal lights and my tandem has leds . when I was getting my brake controler fitted I mentioned the problem and was tol that the tandem needed resistors on the correct wires and that they are reasonably cheap and easy to fit. With the white socket this is a standard European wiring system and is wired into the vechicle electrics .I found plenty of info online about it including wiring diagrams .I could only find plugs available in the UK they are quite cheap however postage is unbelivable , I suggest that if you source the plugs from UK also buy genuine filter kits for your LR as if you buy 2 kits the hole deal works out less than half price including postage
    Doug
    There must be a hundred posts on this in the RRS/D3/D4 section and in tech and trailers - do a search and all will be revealed.
    With the D3 - resistors do not work by themselves and you will also need two relays - can be made for less than $50.
    Sep 2011
    SE Melbourne, AU
    Thumbs up sorted
    Cheers all / Garry.. yes you are right probably thousands of posts out there and you would be amazed at how many of them are incorrect!
    I ended up being lazy and buying an LED TowConnect - not cheap but works a treat and the guys who makes them up was really helpful too.
    The 12S are as rare as hens teeth in Australia so I bought a bag full from the motherland and wired it up myself... fridge now wired to deep cycle battery on jayco and battery charges off mains or 12S running fridge at same time when in transit... ignition off 12S is off (so not flat battery after lunch stop) has fuse /breaker to avoid power shunt and loom melt if deep cycle is flat as...
    Simples.
    Jan 2011
    WA
    Quote Originally Posted by dropbeardisco View Post
    Simples.
    I don't suppose you can show me a wiring diagram and pin outs you used for this could you.
    I want exactly that for the Camper Trailer
    I also bought the LED tow connect product. It seems a lot to pay to correct what seems to be such a silly problem, But really for a simple neat, transferable and removable fast solution rather than messing around adding resistors etc and dodging stuff up it is worth the $200.
