Results 1 to 10 of 15
Thread: What happens if a vehicle is towed in the wrong way
    Sep 2012
    Adelaide
    Quick question on towing an Automatic D2.
    When dads D2 was towed, the RAA bloke just put the vehicle in neutral (the main transmission)
    But i not in the hand book, that it says to put the Auto trans in Park and the transfer box in neutral. Since this was not done.... what damage could occur with the vehicle being towed about 20Kms.
    Matt
    Jul 2010
    Hunter Valley NSW
    Big mistake! Sorry
    You will overheat the transmission and damage likely...
    Sorry do you mean towed the D2 on its wheels rolling?
    Sep 2012
    Adelaide
    im not sure, all dad says is that he was towed 20kms, using a short tow rope.
    Mar 2010
    That'll f...f...fix it!
    Any auto needs to be towed wheels off road, that is on a trailer, or as stated in handbook otherwise the auto will be damaged.
    Hope you got away without any damage, but ........
    Kev
    Kev
    2005 TDV6HSE D3
    2006 V8HSE D3
    99 TD5 D2 (Gone)
    97 RR Autobiography original (Gone)
    Don't panic until you've tested it.
    In Adelaide towing it would be low speed..
    Aug 2012
    Arkansas, USA
    If the transfer box was also in neutral, you'll probably be ok. The small amount that the output shaft of the auto box could move like that would probably take a while to over heat. Putting it in park is best. Now if the auto box was in neutral and the transfer box was in high or low, the auto box could certainly over heat, due to the output shaft being driven by the transfer box without the transmission pump running to lubricate and cool things down.
    I've seen some other makes and models of cars that could be towed short distances like with the auto in neutral, but they would require you to stop every few miles, start the engine, and run through the gears to get fluid everywhere.
    Who cares about cooling the auto becuse the pumps not running?
    I'd be a hell of a lot more concerned about lubing the bearings.
    For most landies its Tcase in neutral auto in park, manual in neutral.
    Sep 2012
    Adelaide
    That's the problem. The tow was on highway 1 between snow town and locheil at 80km's/h.
    Shouldn't the raa guy have known what to do, since that's his job.
    Aug 2012
    Arkansas, USA
    Quote Originally Posted by mattadelaide1975 View Post
    Shouldn't the raw guy have known what to do, since that's his job.
    Yes. Or at least he should have been safe and put in on a trailer or roll back. Around here most of the tow drivers are afraid of causing damage, so if it's 4x4 or awd they won't attempt to tow it unless all the wheels are off the ground.
    Feb 2011
    Hobart, Tasmania, Australia
    Are you actually 100% certain he hadn't put the transfer box into neutral? If he's experienced and knew what he was doing perhaps he just poped it into neutral at some point and you weren't looking or didn't realise?
