Thread: 110 county heating /aircon wiring help wanted
    May 2009
    Hi all
    I just bought a 110 county v8 as a project car, and am in the process of getting it ready for RWC then swap the reg and then the real fun will begin.
    The heater/aircon was in the back, stripped and patched it back together, the fan has two wires coming from it a light grey and a black connected them up to corresponding wires coming from the dash and the fan will only work while the dash switch is switched to fresh air regardless of the position of the fan switch.
    Can any one shed some light on the problem and or direct me to a wiring diagram.
    Michael.
    May 2009
    Sorry forgot to add 1985 county v8
    ROMAROVER Guest
    check the speed resister block adjacent the engine bay fan unit also
    May 2009
    I think that may be where the problem is, there is no Resistor Block]
    There is 2 small gauge wires black and black with white trace, coming through the fire wall, black gives 12v with the fan switch on.
    My multimeter just died so I can't measure resistance, but I am asuming these go to the resistor block as well as the fan power feeds.
    Thinking about using a relay to trigger from the fan switch to the power leads, as i only need a RWC to change the reg and then I will do everything properly.]
    Oct 2017
    Phillip Island
    Quote Originally Posted by fitzy View Post
    Just when you find the topic for the problem you're trying to solve you find a dead thread.....
    I can't seem to find any reference to the fresh air/recirc switch in any County wiring diagrams. Does anyone have any hints as to where this goes / how it works ?
    Nov 2011
    Quote Originally Posted by Zcoota View Post
    The switch in the V8 County I have works on vacuum from the motor. One of the lines come from the engine bay and the others go to the various parts of the dash.
    I did have a diagram when I last put it all back together 20 years ago, and next time I would have to do it I would just try work it out until I have it operating correctly. Someone may have the connections for it, or I can see if it is the workshop manual.
    Richard
    _____________________
    1985 V8 County 110
    1994 TDI Discovery 1
    2000 TD5 Discovery 2
    2010 TDCI Defender 110
    Land Rover Owners Club of Brisbane
    Oct 2017
    Phillip Island
    Cheers Richard. I just assumed it was and electoral switch due to the feel of it. That makes a bit more sense if it’s vacuum operated. I’ll pull the dash apart and have another hunt.
