Results 1 to 6 of 6
Thread: Series Firewall Vent Covers
    Apr 2011
    Wandong,Victoria,Australia
    Hi All,
    I am in the process for restoring my 1960 SWB Series 2, "Roger".
    Roger came with these fancy firewall vent covers:
    I would like to either clean or sand/paint them, but I am afraid of damaging them because they seem to be made of very delicate aluminium / wire.
    Any suggestions? I don't want to damage them.
    As always - any suggestions are greatly appreciated!
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    One I have are aluminium frame but steel wire - still very delicate. I manually wirebrushed them using a fairly soft bronze wire brush, but did not attempt to try and remove all the rust from the mesh, then a light coat of etch primer followed by black.
    Jan 2010
    tom price the pilbra, west aust
    if they are aluminium, then get some spray on cleaner for ali car mags, spray it on let it sit then hose off.
    Cessnock NSW
    They look reasonably clean except for the item bottom right of frame, in the past I have just grit blasted mine using Illmenite and have had no issues with that, anyway cheers Dennis
    smurf village
    if you are only using a small sand blaster they should be fine but as JDNSW said I would wire brush them first to see what the outcome is then
    drifter Guest
    Quote Originally Posted by Dinty View Post
    I did this with mine and they came out very well.
