Results 1 to 10 of 30
Thread: Holden red motor and conversion plate
    Dec 2012
    Stoneville, WA
    I have a 1958 S1 107" with a holden red motor. Sorry I don't know what size the red motor is. It is still in the Landy and is going cheap (swap for 80" parts) minus the radiator and the other original Landy parts, and yes the conversion plate goes with the engine.
    The only hitch is you need to remove it from the car with no damage to the Landy.
    If you have any 80" parts to swap send me a message.
    Jonesy1972
    smurf village
    if you look on the side of the block it will have a number that will say what motor it is most likely a 186 or a 202
    Dec 2012
    Stoneville, WA
    Quote Originally Posted by Landy Smurf View Post
    I had a look but couldn't see a number. What side should it be on?
    Jonesy
    smurf village
    it was on the passengers side I think. what colour is the engine.
    I am not sure if I have asked you this before but what 80' parts are you after?
    darwin, nt
    It should be a large cast 3-digit number behind the alternator/generator. If there is no number there, it's a 149 (low compression, iirc). The engine number in this case should have a single letter prefix (M or Q I think, but don't quote me on it), as these usually came out of EHs. Later engines have the engine size as a prefix. The engine number is on a flat boss near the distributor.
    Dan.
    69 2A 88" pet4 (still in disguise), 68 2B FC pet6 (still resting quietly), plus 13 other project/parts cars (1xS2, 5xS2As, 7xS3s).
    Dec 2012
    Stoneville, WA
    It's a red motor. I had a good look at the engine and I can't find any ID except for a "1". The engine is a recond, from the sticker on the rocker cover.
    As for S1 parts, I am looking for a front grill (full grill for lights behind), "D" lights for the rear, a tail gate, hoops.
    Jonesy1972
    smurf village
    you can still buy the d lights, keep your eyes out for a grill i saw one not long ago on ebay but not very often they come up. getting a good tailgate is near impossible I reccommend getting a new one made up when the time comes. hoops you may need to look for a wreck as they would be a pretty sort after part it is one of the few left I have to get but I have a lot more to do before that
    smurf village
    if you want to know more about the holden engine try holden wikipedia website so much good info on there it should help you identify it, but to be honest if it is seized it is probably worth more as scrap as there is quite a few holden motors around
    Dec 2012
    Stoneville, WA
    Quote Originally Posted by dandlandyman View Post
    Dan.
    Can't find the three digit number, only what appears to be the number "1" on the block near the alternator.
    The number on the flat boss behind the Dizzy is 149D........, so I guess it is a 149. It was reconditioned by Dianella Auto Engineering in Bayswater by the sticker on the rocker cover.
    smurf village
    do you have a few photos of the engine that you could post up
