Results 1 to 10 of 17
Thread: Red light on A.C.E.
    Jan 2010
    Tamworth
    Unhappy Red light on A.C.E.
    The other day i was stoped at the lights and felt the car rocking around ., it was blowing a gail outside so i thought that must have been it though it never rocked like that in the wind before . Then , today again stoped at the lights the engine nearly stalled and the A.C.E. red light started flashing and the chime was sounding . As i was in trafic and not far from home i kept going home . As i pulled in the drive the light stoped flashing and stayed on and red .
    I hooked up the nanocon and it is showing the faults; 04-02 Direction control vavle 2 , current out of range
    circut falt 30
    06-01 Hydraulic pressure too low
    I have checked for leaks and looked for anything obvious but so far nothing. Have any of you had something similar?
    Any ideas on a fix?
    Thanks in advance , i would very much like to get this sorted .
    Cheers , Bill.
    NSW SW Slopes
    Can the Nanocom operate the direction control valves to test them? Excepting for the pressure too low fault, I would suspect a faulty coil on the particular direction control valve. With the electrical connector unplugged from the valve block the resistance of the coils can be checked, assuming you have access to the wiring diagram and a multi-meter. It could simply be a bad electrical connection at the valve block.
    Jan 2010
    Tamworth
    Thank you , I will check this out , unfortunately i have been called away to work for a couple of weeks so cant get started on it right away.
    nanocom can do assorted tests on the ACE system (will make some horrid sounding noises to accompany)
    Oct 2010
    sydney
    my one started flashing red yesterday.
    i drove it home, popped the hood and there was no fluid in the resevoir.
    woke up this morning to top it up, popped the hood and it was full.
    drove down the street, red light starts flashing again so i stopped the car, popped the hood while engine was still running.. empty again.
    turned the engine off and saw it filling up veeery slowly,
    what going on???? anyone??
    NSW SW Slopes
    Air in the system so somehow it has lost fluid.
    Oct 2010
    sydney
    thanks for that, now how do i bleed the system?
    Nanocom
    Oct 2010
    sydney
    noooooooooooo.... i found a serious leak from the top of the actuator (front right wheel arch)
    i need to fix this asap then get it bled. is it hard to replace? does anyone know how much thinner my wallet will get??
    i saw actuators on ebay for around $120 for OEM.. what would LR want for one??
    Oct 2010
    sydney
    wow. after a bit of searching, im starting to think that noone around here has actually replaced the front ACE actuator.
    or is there a fix for the leak without replacing???
