20th January 2013, 05:20 PM
Lower tailgate straps
Is it possible to use or modify the scissor hinge off a classic to replace the cables on the p38 lower tailgate. After I had one rust out, I don't trust them any more. I hope this hasn,t been covered before because I did search and couldn,t find anything!
20th January 2013, 06:52 PM
You can buy them relatively cheaply. Wonder if there is some stainless ones around.
I doubt one could be modified. As in the closed position the relative height of the tailgate and pillar pins would have to be exactly the same.
21st January 2013, 09:13 AM
If they're the originals, then they were made of a poor quality material.
A bulletin was issued for the problem, NRR/76/33/95/EN.
Part # ALR5237 is supposed to be a better cable.
21st January 2013, 09:39 AM
#4
Ok thanks, I,ll see if I can get some, but it always amazes me that they would change from the tried and tested classic ones to a poor quality crappy one.
21st January 2013, 10:32 AM
#5
I agree the Classic type were a lot stronger but probably overkill really.
The Classic stays also had a habit of swinging when the tailgate was closed creating the odd knock on braking/accelerating.
