Results 1 to 10 of 18
Thread: Hevac Fans
    Coogee, South of Fremantle, WA
    Hevac Fans
    Have lost all fan speeds, presumably both fans have stopped together.
    Have read loads on other sites but am confusing myself. As both Fan have stopped I am looking hard at the fusebox, relay 7 works but is burnt and the fusebox shows the dreaded signs of long time overheating. fuses OK
    Questions, do both fans stop if relay 7 and its connection go bad.
    Is there a quick way to test the fans independently, I see the fans are quite easy to get at, can I just hit them with direct 12v to test, if so where.
    Regardless i will be getting a replacement fusebox and in the meantime if the blowers prove ok will follow Rons repair until I can find a guaranteed used one
    May 2010
    Mindarie, Western Australia
    Wayneg
    Quote from RAVE
    "Left/Right Blower modules
    The blowers have a permanent 12V feed to them.
    The speed of the motors is determined by the control
    lines which go to the motors. The motors also
    provide a voltage feedback to the HEVAC ECU to
    determine the actual voltage at the motors but also
    to show if there are any faults."
    So, in answer to question yes 12v direct to motors is OK, as it should already be present. Also check Fuse 42 and 43 in engine compartment fuse box and fusees 17 (10A) and Fuse 8 (30A) under the drivers seat fuse box.
    With the warm weather forecast you're going to need more than an open window.
    Good luck, I hope it's not a new control panel!
    Gary
    Oct 2007
    Williamstown, Victoria
    The relays are interchangeable, green for green, yellow for yellow, I would try swapping another of the same colour relays in your fuse box over with the fan relay to see what that does.
    Burned relay housing means it's been very hot, which would indicate a potential heat damaged relay.
    Worth a shot and does not cost anything.
    Cheers, Pete.
    Done some digging and the fans work fine . No power getting to the fans so all points to the fusebox, Bugger. Now lets hope its as straight forward as Rons instructions to dismantle the fuse box for a repair. Anyone got a spare Thor fusebox they want to part with?
    Oct 2007
    I've seen complete new P38 fuseboxes on ebay,
    http://www.ebay.com.au/itm/LAND-ROVE...item2a2107912a
    might be worth investigating?
    Quote Originally Posted by PeterH View Post
    LAND ROVER RELAY FUSEBOX FUSE BOX COMPARTMENT RANGE P38 99-02 YQE103410 OEM NEW | eBay
    There are plenty of used in the UK for 15pounds its just a time thing, I will R&R mine and get one for spare.
    May 2008
    Quote Originally Posted by wayneg View Post
    I have a spare here that is out on loan to a mate. Pretty sure I will get it back soon and can send it to you. When you get a replacement, send me the better of the two
    NSW Far South Coast
    I'll drop it off today, Paul. Thanks.
    May 2010
    Wayne, what year is your P38. I also have a spare (complete with all relays) in the garage for a GEMS 96 model. I will be South of the river later today if you want to use it until yours arrives.
    Gary
    Paul and Gary, Thanks for the offers, I will just hold fire on taking you up. I intend to take mine out tomorrow for a fix , if all goes well I will be ok till I get one sent from the UK. If things dont go to plan I will be in desperate need as on the 4th Feb I will be crossing the Nullabor and cant think of how hot the car will get with no fans.
    Paul as you have the Thor unit I might require I will PM you if I need it if thats OK.
    I cant believe I have had two offers of a loan part, as always the Landy community comes to the rescue.
