Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Small Welding Rods
    Small Welding Rods
    I just bought a small BOC Dc inverter stick welder to do light work on the cars. The smallest rods I have found are 2mm which are just a bit too big for some of the sheet metal I have to weld. 40 amps is barely enough to fire up the arc but more than enough to blow holes in the metal. I really need rods about 1.5mm or even down to 1mm so I can run about 35 amps to fire up the arc and not blow holes.
    I have searched the net but cannot see any one that lists rods smaller than 2mm. So any one know if stick rods go smaller than 2mm and where you can get them.
    Aug 2012
    Adelaide
    2mm are the smallest I could get too.... Hence i went to a mig welder
    Quote Originally Posted by debruiser View Post
    Thanks - I have a mig but it is just too expensive to use with bottle hire etc.
    scanfor Guest
    Hi Garrycol
    I too abandoned the MIG in favour of a DC stick inverter based on gas costs. I have also found that it won't reliably do the small gauge stuff that a MIG can handle, even with tiny rods.
    I am reliably told that my technique could be adapted to better suit the inverter, and it may help to do short welds to keep the parent metal temps low.
    Jan 2013
    bundaberg
    Yinnar South, Vic
    MIG for panel work, nothing else, ARC will NOT do the job well, unless you are an excellent welder
    Irymple, Victoria, Australia
    Instead of renting mig bottles which is an asolute fortune there are disposable bottles available. I have not tried them yet but a workmate recently got one and it was about $40 bucks plus a one off cost of about $45 bucks for an adaptor fitting. Basically the cost bottle rental alone will buy you five disposables a year!
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Jan 2013
    Tasmania
    Small Welding Rods
    I've welded motorbike exhaust with 2.5 rods.......but it was ****ing hard!!!!
    Also not terribly neat...
    Stopped the bike being so noisy though!
    Really arc is too grunty for panels.
    Quote Originally Posted by mick88 View Post
    Cheers, Mick.
    I have them and are not worth it - just too expensive to run as the gas does not go very far. Is cheaper than renting larger bottles etc. That ebay link above also has larger bottles for $85 (nearly $100 with shipping) that may be better.
    For the work I am wanting to do arc is fine if I can get smaller rods which it would seem are available on ebay.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    switch the polarity and run gasless wire on the mig
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
