Results 1 to 10 of 11
Thread: Puma Bump Stop Clearances
    chook73 Guest
    I have done a fair bit of searching and I cannot find anywhere the bump stop clearances of a brand new stock Puma with no accessories fitted. I have found a lot of posts that put the front somewhere between 65mm and 85mm and the rear somewhere around the 100mm to 120mm but i havent been able to find anything convincing.
    Does anyone have them please?
    Feb 2009
    I asked my dealer to report for me. They used a 130 with an alloy tray fitted. They quoted 100F and 150R. When I had a look for myself I felt the front was 85 to 90.
    I just so happen to be working at a clients house at the time who had just bought a 110. Again I'd say 85 to 90, and the rear was 125.
    Jason
    2010 130 TDCi
    chook73 Guest
    Thanks Jason.
    Iain
    Be careful when looking for bump stop clearances,as it depends where the measurements are taken from,as the distance from the rear of the bump stop to the rear of the bump stop plate on the diff will be different to the front of the bump stop to the front of the bump stop plate,due to the rotation of the diff.This is why is is difficult when lifted suspension has been fitted because the diff rotates even more.I suggest you ask for measurements from the centre of the bumpstop plate on the diff to the centre of the bumpstop.
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    chook73 Guest
    Quote Originally Posted by LowRanger View Post
    Iain
    Thanks Wayne I had read this in another post, frankly with the variances in measurements I have been given it wouldn't matter where I measure from as there is over 25mm variance.
    I have the stock spring measurements (from Gwynn Lewis) I was just hoping to have a comparative measurement to stock as a backup.
    Quote Originally Posted by chook73 View Post
    Take a trip down to the local Dealer and measure for yourself.Tell them you are just checking out the underneath before you will consider buying
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    chook73 Guest
    Funny I was just thinking that.......
    Ask them if I can trade my truck in and see what they say!
    Stockton, NSW
    I asked the some question a few months back, had a couple of replies -
    Puma suspension height
    IMHO it is not practical to accurately measure bump stop clearance.
    Not only the for the reason lowranger gave but the suspension changes which occur on surfaces that are not dead flat and level (spring rates also influence these particular changes).
    Then there is the difficulty of obtaining an accurate measurement.
    If six people measured the same vehicle you would probably get six different measurement. If the same six did this 3 times each, but on 3 different days, you would might expect close to 18 different measurements.
    chook73 Guest
    Quote Originally Posted by Bush65 View Post
    Thanks John, I am just looking at a comparative measurement as so much has changed on the vehicle it is hard to get an accurate measurement and be able to compare it to stock. I also got the measurements between the spring seats and I just wanted to make sure we were in the ballpark which is seems we are.
    I agree with both of you which is why I didnt have any measurements at the bumpstops previously.
