Results 1 to 10 of 23
Thread: Yes, another spare wheel carrier question
    Apr 2012
    Engadine NSW
    Hi all,
    Has anybody attempted to modify there standard rear bar to incorperate a spare wheel carrier. I'm desperately trying to find a solution to the spare wheel dillema and I really don't want to put two on the roof, and I'm trying to avoid the hitch receiver gizmo
    Thank in advance,
    Rob
    Feb 2010
    Townsville, QLD
    I too am wondering if it would be possible to weld a stub axle to the chassis and cut out a section of the rear bumper to make this possible. It's easy enough to remove the bumper, wonder how hard it would be to do... Shame I suck at welding...
    Keithy
    Apr 2012
    Engadine NSW
    Yeh Keithy, That sounds like someway towards an idea.
    What about a bracket setup either welded or bolted to the chassis that supports the stub axle ( to get it out toward the corner of the car ) and as you say cut out the bumper. Would there be enough strength in that I wonder?
    There's a guy in Gelong who provides a basic kit that forms the basis of the whole carrier. "Rijidij" is the name, and the guy's name is Murray, he seems very helpful.
    Rob
    Quote Originally Posted by Keithy P38 View Post
    Keithy
    If I understand what you are getting at, there's a practical problem: the chassis rail (both sides) is located about a hand span inside the outer extremity of the lower tailgate Which is why the commercial versions have the stub axle at the very end of the rear bumper....
    EDIT: on further thought, the Moment exerted on the single chassis rail by a bracket supporting the weight of the entire frame plus spare wheel, would cause it to deform. You need to both chassis rails and a solid bumper I would have thought to support the weights involved. It's not just the static weight of the carrier and wheel but rather the significantly increased forces applying when travelling "in harm's way"
    Apr 2012
    Engadine NSW
    Would the chassis rail support such a bracket that far away from the fulcrum, what ,about 200 mm I guess?
    How do other vehicles cope with this I wonder?
    So that why the D3 and D4 bracket bolts through the bumper!
    Apr 2012
    Engadine NSW
    Quote Originally Posted by Hoges View Post
    Way to quick with your edit Hoges
    I have one (a through bumper stub axle type swing arm) that I am pretty sure was made by Hardy Neale (original HardRange owner). It came to me a few years ago via Willem (a fellow AULRO member) down near Geelong.
    I even saw photos of it fitted up on a P38 (perhaps Paul's hardrangie, pre HardRange sill stickers?) on RR.net too from memory...
    Anyway, I am pretty certain the setup is still somewhere under my house, will dig it all out and post photos tomorrow.
    Hoo-Roo,
    Dave.
    Feb 2010
    Townsville, QLD
    I like the sound of that Dave. The seed has been planted.
    So to make a brace that crosses both chassis rails and extend the stub out of the lower tailgate's way seems to be the best way both structurally and practically (of course). Not forgetting the need to place a set of lights on the bumper as well - perhaps LED strips?
    Overtime is taking my R&R at the moment but when I do next get a decent bit of time off ill rip off my bumper and assess under-bumper clearances.
    Keithy
    May 2010
    Mindarie, Western Australia
    This sounds like a plan! I like the idea. If someone has one of the pics it would be great to have it posted.
    Gary
    Douglas Park, NSW
    There was a car at the recent NSW Expo with a set up like this. I'll load some photos tomorrow but I didn't take any undercar shots.
