                                                5th February 2013, 10:05 PM
			RRC Flexi Coils in a D2
					I have been looking for some flexi coils to go under the D2 however have had no luck finding anything listed.
 I did however find these;
 Range Rover 3" lift Flexy Coils x4, Suspension Stuff
 So my question is, would RRC coils work in a D2 and does anyone know what the difference between standard coil lengths would be, between the D2 and a RRC to confirm if they would be a 3" lift in the D2.
                                                10th September 2015, 05:03 AM
					Curious about how you went?  Looking at the same situation
                                                10th September 2015, 08:13 AM
					I have fitted RRC "green" OEM rear springs to the front of my D2.
 They give about 30MM lift to a TD5 D2 , vs about 50MM lift to a RRC V8, which is probably about what you would expect for the engine weight difference.
 The D2 has a socket for the front spring at the bottom, so I cut a bit off the taper so that it would sit in the socket.
 I spoke to Les Richmond's son about it and he said that they use RRC springs all the time on D2s.
 The rears may be a bit different ,as D2 usually has much higher rated springs as no Hydromat, but I think the lift is similar. I have 50 MM Kings in mine.
 Regards Philip A
