Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Right is wrong
    Right is wrong
    When one thinks they know it all, along comes something to trip them up.
    'Inc' wanted a shield for the back axle brake pipe, right hand side and so I dually located, removed, inspected and sent a example of required item.
    What could be simpler?
    Well, after a while Inc sent me the message, "it's for the wrong side"!!!!
    I'll pause now and throw the question open to all of those who know.
    Why is it that, right is wrong?
    He got it wrong?
    try again
    Quote Originally Posted by clubagreenie View Post
    He got it wrong?
    No, we were both right, so how did Inc end up with the wrong one?
    Queensland
    What car was it for?
    On an 80 the shield is in front.
    86 on etc its on the back.
    front to back
    Quote Originally Posted by 123rover50 View Post
    What car was it for? On an 80 the shield is in front. 86 on etc its on the back.
    Thanks Keith
    This forum is great, I didn't know about the forward placement of the shield on a 80" either.
    The Land Rover in question belongs to Inc, and that is all I thought of at the time, I would have to go back and read that thread again to see if the model is mentioned.
    I'll leave the answer for now, to give someone else a chance of addressing the question
    Seaforth NSW
    Brake pipe shields introduced with 1949 model.
    Service Bulletin 5043, Date issued 23.2.49
    Fracture of Rear Brake Pipe
    Complaint: Complaint of Brake Failure or Fracture of a rear brake pipe at the point where it passes between the rear shock absorber and rear axle check strap.
    Cause: Under normal circumstances the flexible check strap is slack; movement of the rear axle may allow the strap to chafe on the brake pipe, ultimately causing a fracture and consequent brake failure.
    Remedy: Renew the rear brake pipe andfit a suitable shield betweeen the check strap and brake pipe on each side of the vehicle.
    The Bulletin goes on to describe the introduction of the shields (free of charge) LH #232089, RH #232088 and also gives a dimensioned drawing so the shields "may be made locally"
    "Vehicles produced in future will be equipped with shields on assembly. In addition, each brake pipe will be secured to the shield by means of a clip Part No. 56666, rubber bush Part No. 06860 and drive screw part No. 72626."
    Bob
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    but whats the long and the short of it?
    such a learning curve..
    makes the mundane very interesting..
    when is the above lefthand or righthand ?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Wouldn't it be relative to the orientation of the housing?
    A RHR would be LHF.
    Seaforth NSW
    Depends on the brake pipe position
    clubagreenie snip - Wouldn't it be relative to the orientation of the housing? A RHR would be LHF.
    Early vehicles had the brake pipes across the differential casing on the front side and later vehicles have the brake pipes on the rear of the differential casing. Series 2/3 IIRC have two of the clips with rubber bushings per side and they are bolted up with 2BA(?) bolts, nuts, spring washers.
    Not to mention the way you bolt up the checkstraps - they are on the outer face of the chassis rail.
    Bob
    Clue
    Quote Originally Posted by bobslandies View Post
    ------- and fit a suitable shield between the check strap and brake pipe on each side of the vehicle.
    Clue.
