Thread: number plate light?
    Aug 2008
    latrobe valley victoria
    number plate light?
    hi all
    just a query re the tailgate mounted bracket and plate light
    is this a common peice aka 2, 2a
    or series 1 specific ?
    regards mark
    JDNSW's Avatar
    My 56 S1 had one that was, as far as I can remember, identical to the Series 2/2a/3 item.
    I suspect this is Australia specific, and probably varied at least in detail over the years.
    australia
    Quote Originally Posted by mfc View Post
    hi all
    regards mark
    hi yes s1 s2 s2a when tail gate down swivils to be seen
    Jul 2012
    Oz spec
    I believe this is correct - the UK models generally had the rear license plate located on the offside left rear panel of the tub. The Australian trucks, and possibly some other export models, got the centre mounted light and pivoting bracket on the tailgate. It probably had as much to do with the shape of the local number plates as anything else.
    From memory, you will find this detail in one of the Taylor books.
    no plate
    Hi
    the main reason for the swing mount was to allow the no. plate to be seen when the tail gate was down
    Ian
