hows the airflow from the fan?
dont foget that the intake manifold is ontop of the exhaust and turbocharger directly attached to about the hottest part of the head, all of its aluminium and would take probably about 3 nanoseconds longer than the crank shaft takes to stop to begin to heat up to some reasonable temps.
 I'll do a couple of tests make sure its all working as it should before the next run.
