Results 1 to 10 of 16
Thread: Etching primer
    Jul 2012
    Etching primer
    Hello from Brisbane.
    I have a few small painting jobs to do that involve unpainted aluminium panels. These are all inside the cab in low wear areas.
    Can you get etching primer in aerosol packs?
    I have previously used a pot and brush and, try as I might, couldn't completely hide the brushmarks with the aerosol grey primer and semi-gloss black finish coats.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    yep
    i get mine from the local autobahn or the local aero parts shop.
    the one from the aero parts is usually dearer but i find it way better i have to say.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Narre Warren South
    White Knight & Wattyl supply etch primer in rattle cans.
    I've found that Masters are the best price (just under $10 per can)
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jan 2009
    On the road around Australia
    Quote Originally Posted by gromit View Post
    Colin
    Solver paints do aluminium etch primer for about the same price.
    What ever you use I hope you have better luck than me
    I am VERY anal about prep. Sanding, cleaning and then wax and grease remover or acetone.
    I just did some shocks, so not even aluminium. Sanded, cleaned, acetone. Then K&H etch primer, followed directions. After final etch coat it was left to dry for about a week. Started the top coat with K&H engine enamel did the first coat. That was left for atleast a week. I then gave it a lite rub down with 600g sandpaper and then went to clean with acetone for next coat........
    Both top coat and etch primmer rubbed right off, back to bare metal/paint
    I can only think that I applied too much in one go, and even though left for a long time, it never cured....touch dry, definietly, cured NO.
    I am now trying again. My coats will be VERY thin and given 2 days to dry. So it will take me atleast 6 days to do the etch then 2 weeks to do the top coat.
    I have a horrible time with paint I dont think the humidity here on the Gold Coast helps either........
    Jul 2010
    Hunter Valley NSW
    Etch primer should be used on new unsanded bare metal only, I used epoxy primer.
    Cleaning new paint with acetone! Only use W&G remover.
    See link. Ask questions very helpful when I repainted the falcon.
    when to use self etching primer - Hot Rod Forum : Hotrodders Bulletin Board
    Ok, so who here is a chemist? I would really like to know the difference between Acetone and W&G remover (100% hydrocarbon)
    While I have had issues before, I have also had good succsess. Remember that most of those guys would not have been talking spray/rattle cans, but quality paint to apply with a proper spray gun. Yes there will be similarites, but you dont have the range of quality in a spray can.
    Any decent painted surface, that has cured properly will NOT simply whipe off with a rag and acetone.
    btw, they were only referring to steel. The OP was talking about aluminium. Any non-freous metal needs etch primer. Zinc coated, Galvanised steel, Aluminium etc. Giving them a light sand and thorough clean is only going to be of benefit IMO.
    I am happy to be proven wrong, but how is sanding a aready painted surface, back to bare metal in some areas, going to cause a failure with etch primer?
    Narre Warren South
    Quote Originally Posted by uninformed View Post
    I'm not a chemist but wax & grease remover seems to be petrol based.
    Septone is white spirit (dry cleaning chemical used instead of Turps in the UK) & petroleum
    http://www.septone.com.au/msds/ASWG1.htm
    Are you sure acetone isn't a solvent for the paint you're using, it makes a mess of my nail varnish....
    I'm etch priming bare steel, sanding lightly & painting with epoxy from a rattle can the same day. Dry in a day or two (depending on the temperature).
    White Spirit details here http://www.recochem.com.au/index.php..._white_spirits
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Ive got all "diggers" brand. W&G remover, says on the side being 100% hydrocarbon. Acteone just says 100% acetone haha. BTW, when i first started to rub the painted shock with acetone, I thought "oh no, wrong stuff" switched rags and started on another spot with W&G remover...same result. Paint simply had not cured properly IMO
    While painting all that in one day may work for you, I have a couple of questions. How long are you letting the etch dry? It states on my can to coat, second coat within 5 mins, additional coats within the hr or after 24 hrs. Complelely dry in 24hrs. And how many eypoxy coats are you applying over that in one day.
    Humidity here plays a major role.
    here is the tech stuff from Diggers. They list, among others, the W&G remover and Acetone under their "solvents" banner
    http://www.recochem.com.au/files/dow...tone_Sep11.pdf
    http://www.recochem.com.au/files/dow...over_Sep11.pdf
    and here is their enamel thinners, which has its same main ingredient as the W&G.....isnt thinners for thining out paint AND clean up/removal....
    http://www.recochem.com.au/files/dow...ners_Sep11.pdf
    smurf village
    im glad this topic has just come up as I have been thinking about it lately.
    I would like to see the quality of the pressure pack as it is cheap and easy to use
