Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 144
Thread: How long is the life of your D4 battery?
    Dec 2009
    Question How long is the life of your D4 battery?
    The battery warning light just came on in my D4, and stays on when ignition is off. The car is exactly 3 years old.
    I was wondering if this is reasonable for a D4 battery to last, or whether my recent install of a CB radio wired directly to the battery might be draining the battery (although the CB has been kept off and unused for all this time)? I just don't want to go replacing the battery if the underlying cause is something else (ie the C.
    I know this is somewhat of a "how long is a piece of string" and also a "your milage may vary" issue, but still interested in your experiences. The car is used daily for city use and many short (<10km) trips a day. Longer trips on weekends.
    I will also try charging it up with a battery charger and seeing how long it will last.
    Douglas Park, NSW
    Looking at this post nearly 3 years ago:
    http://www.aulro.com/afvb/d3-d4-rrs/...my-garage.html
    your battery is still under warranty.
    Roadside assist will replace it for you if their tests confirm it's a battery failure.
    Dec 2009
    Hah hah, yes, the car's 3rd birthday will be 23/3/2013, so I will also give the LR warranty a go. Thanks for that note!
    NSW SW Slopes
    Do you happen to have the earth for the UHF going to the battery terminal?
    Mornington Peninsula
    Why do you ask that Graeme?
    Dec 2009
    No - it goes to the earth bolt that is outside the battery box, below the positive terminal (where lots of other things seem to be earthed). This was based on advice in the thread asking about power for the CB.
    Dec 2009
    SW WA
    My battery just got replaced after 20 months and 50K kms, it was covered by warranty.
    Interestingly they replaced with a AGM battery rather than the original Calcium Battery.
    Feb 2010
    Mount Martha
    Mine was one of the first of the D4's......December 2009.
    Had to replace the battery at around 83,000 Klm's.
    Cheers, Craig
    My mid 2007 RRS is still on its first battery.
    Dec 2009
    Mine lasted only two years. It was Varta and was replaced under warranty with a Korean product. Can't be worse than Varta, I hope.
