21st March 2013, 12:22 PM
Noisy Alternator
My 300Tdi alternator (original I reckon) is starting to make some grinding/squealing noises, causing me to suspect imminent failure.
I have it on good authority that the bearings might be replaceable. Despite this, I'd like advice on prices/brands etc for a replacement.
Any suggestions/recommendations?
21st March 2013, 12:39 PM
i have a brand new (disco) one sitting in the shed..........i brought mine from M R. happy to cut you a deal (i two thought mine was failing but it ome good).
if you believe it will last longer enough to import one that would be your cheapest option
i upgraded to a disco alternator a few years ago as they are higher output. i also run the disco suepentine belt as i couldn't be bothered changing the pullies over
