I think I've got a brand new spare in the garage you can have if you want it Inc. Or do you just want the measurements for reference?
what a merry chase!
starts out as part number 213744
goes to ERC7987
then ERR1632
and ends up being current at ERR6490 it seems
same seal used on all four and eight cylinder engines...
cheap version is $3.00 dear version is $25+ it seems
any of you fine upstanding people know the dimensions / specs on the dear little thing ?
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
just wanted the specs at this stage, thanks
and thought i would list it to save someone the same frustration if they were looking for the right seal..
seem the one on madge has collasped so was doing some research getting prepared to do the job.
next i have to find out if the front pulley etc is the same as the later variant....
OK, so I have an ERR6490 in front of me.
Outside diameter 63mm
Inside diameter 49mm
Depth (outside edge) 9mm
Depth (inside edge) 10mm
Low res photos attached
Just shout if you want it, and I'll bung it in the post.
