Have you got a ERPS system on the landy, my mates got a pootrol and since he's had the ERPS system put on he reckons the bull bar is being used as a sacrificial anode!
Most of the bolts holding my fender together are rusting to some extent - the door hinge bolts are probably the worst. I can understand this to a certain degree - I've taken it on the beach quite a few times, and I'm pretty sure the previous owners did the same. But there are some bolts which to my mind just shouldn't be rusting. For instance, I put on a wheel carrier a couple of years ago, and I've not been on the beach since then. Yet these bolts have started rusting, with no exposure to salt water at all. Seems odd to me ...
Nope, no ERPS.
Did you use mild steel, high tensile or galvanised bolts/nuts?
ERPS does not work. All stories to the contrary are anecdotal with no basis in fact or science. For your problem, especially with your liking for the beach, a good spray with lanolin or the like, about a litre every 12 months and your Defer will thank you.
Is there science to say it doesnt work? I suspect there is some pretty basic science to say it does work while trying to recall way back to my material science and chemistry lectures. Whether it is usefully effective may be a different story.
I suspect it may have something to do with dissimilar metals reacting also, where the steel is sacrificed. Much like the door frames rusting.
Slunnie
Yes. Lots. Physics is more relevant to this than chemistry. The subject has been discussed ad infinitum but, basically, the whole car has to be surrounded by a conductive medium for ERPS to work (which is why it is used on ships) i.e instead of just driving along the beach actually drive it into the ocean and leave it there, it will work until its power source expires.
Also see 'Post Purchase Rationalization' http://en.wikipedia.org/wiki/Post-pu...ationalization
"Ye' Cannae Break Th' Laws o' Physics!!"
The bolts came with my Bearmach wheel carrier, pretty sure they would be high tensile steel.
I've used fish oil to slow down rust, it seems to work pretty well. My main question though is why the bolts on my wheel carrier have started rusting, when they've never been exposed to salt water.For your problem, especially with your liking for the beach, a good spray with lanolin or the like, about a litre every 12 months and your Defer will thank you.
Rust happens at the interface between the wet and dry metal, even not drying water off after washing or rain, not just sea water. The only effective prevention of oxidization is a barrier on the metal i.e. paint, galvanizing with zinc or a coating of oil. After washing and drying, try a light spray of WD40 on the bolts to give a protective layer.
Hey guys, mine lives in Canberra and still the bolts show corrosion. Just crappy pommy cad plating. Nearly all the posi-drives have corrosion in the drive from the installing tool taking the cad off.
Its a bloody LR
RF
