Results 1 to 10 of 14
Thread: Rear Hub Bearing part number?
    I have done a search here on non-gen replacements for the bearing 07296 (or 270604) and popped off to my local bearing bloke for a nice high quality (ie not britpart) bearing. I had SKF or FKC 88128 as the number.
    I was then asked 88128-R, -RA or -RB?
    which one is it?
    Russ
    Aug 2011
    Albany WA
    Hi Russ
    Ive just fitted new brgs on Klonks rear axels, have checked the invoice and no letters after the part nos. The brg company said they were the ones used in Ford F150 rear axels, so figured they would be fine for a land rover. Sorry dont have the packet now.
    I removed the inner bearing seal when fitting and half filled the space between bearing and seal with bearing grease as there is not much in the bearing, dont fill the space,this allows for expansion when hot.
    Cheers Steve
    Narre Warren South
    Quote Originally Posted by rfurzer View Post
    which one is it?
    Russ
    R & RB are listed here. TIMKEN BEARING part number system (nomenclature)
    Did the bearing bloke explain what the letters stood for or was he just looking through a bearing catalogue and didn't know himself ?
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    colin - the latter
    Thanks for the link. Unfortunately I dont understand the difference even when spelled out in the attachment.
    I have been offered some old stock bearings labelled for S1 Land rover rear bearing use that are 88124 rather than 88128.
    Soooo confusing.
    Furthermore, the F100/ F150 ones (said to be the same) have at least three variations on 88128 including R, RA and RB. There are some F100/150s that use a different size item too.
    Russ
    Narre Warren South
    If I remember I'll see what I used when I did mine 3/4 years ago. I think I still have the box and the old bearing somewhere.
    I just took the bearing in and got them to match it.
    The R & RB don't sound right but, yes, it isn't clear in the description.
    Can't find 88124 via the internet.
    Another part number shows up here 514003 as a replacement for the 88128 (probably a Ford number)
    http://www.dezertrangers.com/vb/truck-talk/148935.htm
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Sep 2006
    Warragul
    Fergy
    Just to confuse things. Ive been told the 1950's Grey fergy tractor uses the same wheel bearings
    Mike
    Narre Warren South
    The ones I fitted were 88128R.
    I left both seals in place because the grease used during factory assembly should last the life of the bearing.
    The ones I removed had blistered rubber seals due to the brakes being partly jammed on ! Still well lubricated and I only changed them 'just in case'.
    Mike
    Grey Fergie seems to use taper rollers but perhaps they changed at some point ?
    http://www.agrilineproducts.com/part...uson_te20.html
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2009
    S.E.Qld
    This is one I removed from a S1 semi floating half shaft.According to my bearing catalogue, 88128 and 407592 are of identical dimensions.Seals on both sides. L/R no 07296 . Maybe the number changed, when the seals changed from metal to "rubber". .W.
    Aug 2011
    Albany WA
    Called in to the brg company we use at work while getting other parts. Asked about the letters, and was told that they usually refer to types of seals, corner radiases on the bearing and circlip grooves. He was abit busy to look up the exact listing.
    Also he said a third to a half of the capacity inside the wheel brg is ok to fill with grease.
    At work we run five road trains from Albany to the Pilbarra, all the hubs are half full of grease and we've never lost a wheel (touch wood). The company next door also run trucks, they only used to pack the brg and leave the hub empty. They lost ten Wheels last year. (two tyres,two rims and a brakedrum = one wheel x 90 kph).
    Thats alot of death and destruction if you get hit doesnt matter what size vehicle you are in. They have now changed that.
    Just something to think about next time you see a truck and trailer comming towards you.
    Cheers Steve
    Narre Warren South
    Quote Originally Posted by klonk View Post
    Cheers Steve
    If you overpack a bearing with grease you get 'churning' which causes heat.
    I've always wondered about those trailer hubcaps with grease nipples and can imagine people pumping grease in until it forces out past the seal !
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
