Results 1 to 10 of 11
Thread: Jump started, now running rough
    Scarborough, QLD
    The old man just jump started his TD5 after a flat battery from no use in a couple of months, and as he drove it around the block, it was running pretty rough. Idling was fine, but on acceleration spluttering, missing and overall didn't sound great. Understand, he's certainly no mechanic, and this was the best description he could give.
    Any ideas what might be the problem? Could not driving it for so long, and not giving it a good enough test run be the issue? Would giving it another test drive be an option?
    Jan 2010
    Adelaide
    Low battery voltage?
    Old fuel?
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by Ranga View Post
    whats wrong with holding the revs at 2000rpm while in the driveway?
    that way if something happens, your still in your driveway and not somewhere else
    Apr 2012
    Orange, NSW
    Could it have gone into limp mode from the jump start?
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Scarborough, QLD
    Quote Originally Posted by SiddersC View Post
    Old fuel?
    That's my thoughts.
    Quote Originally Posted by Disco Muppet View Post
    That's what I was more worried about
    Nov 2012
    penrith
    Did you use normal jump leads or the safety type
    Safety type? What's different between 'normal' and 'safety' jumper leads?
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by Ferret View Post
    the cost, nothing else
    At least if it started there's nothing fried absolutely.
    While there's a limp mode (for instance, in the V8 if a MAF fails the auto can go nuts, cut fuel, add fuel and generally be unpleasant) there's no setting to turn it off. It seems to be based on sensor input and what the ECU likes and doesn't like.
    Nov 2007
    On the road.
    disconnect the battery neg and see if that resets it.
    also a new fuel filter would not harm if been sitting a while.
