Looks good Hoppy 11. Are the rear mounts onto factory cross bars or Rhino bars? If Rhino did you use factory nuts into the tracks as for the front? Regards David
 Fossicker
						Fossicker
						Hi all. I have just fitted the rack to the D4 and thought I'd share the pic of it and what I did. My Disco came with the factory long racks and Rhino recommend a leg that is quite high, too high for my liking so I bought the legs that suit the Rhino track because they are much lower then I bought the track nut that fits the disco's factory track, works a treat.
Defender MY21 D300 SE: Off Road Pack,Explorer Pack, OEM Bull Bar, GME XRS, Tow Pro Elite, Ironman winch, spotlights & light bar, front undershield, Tough Ant 18" brake conversion kit: BFG K02 LT265/70/18
Gone: Fuji White MY14 HSE; Silver D3 MY09 TDV6 SE
 Fossicker
						Fossicker
						Hi there Blue C, there are no separate cross bars, the legs mount to the racks own cross bars, the rack comes with two fixed cross bars and you need to bolt/ rivit 3 extra cross bars to the rack to suit your vehicle. I used the rhino legs that suit the Rhino roof rails, I had to order the Rhino roof rail nuts to suit the Landrover roof rail
 Fossicker
						Fossicker
						Here is a close up
 Fossicker
						Fossicker
						And another, the front legs use a 10mm spacer as the roof rails are not level
 Master
						Master
						Is that a true black option pack, or have you completed yourself? I'm looking at doing the kit myself as it wasn't available on base model ( the max I could stretch my budget)
 Fossicker
						Fossicker
						 Master
						Master
						It looks hot.... Wish I was able to stretch that far... Still at least I got the 8speed, now just have to wait till June to drive it
Hay Hoppy,
Great stuff, looks good!. Do you have the part numbers for the legs and the bolt to fit the LR tracks? I have the 'too high' issue with my Pioneer Platform rack. The legs that Rhino sold me with the rack is as you say too high.
I have the LR long rails same as you.
 Fossicker
						Fossicker
