Thread: source for balljoint gaiters?
    Avoca Beach
    Anyone know a source for balljoint gaiters or a part number?
    One of mine is gone though the ball joint ( lower LH)seems OK.
    Geez every problem on this car seems to be hours of work to fix or get at or cost a fortune.
    eg remove headlining to fit new plip receiver.
    remove inlet manifold to fix Fuel Pressure regulator leak
    remove bloody balljoints to replace a gaiter.
    Maybe I will cut one then slip it in and glue it with superglue.
    Regards Philip A
    Disckombi Guest
    You could try someone like PEPS or AutoOne - my local PEPS carries and can get balljoint gaiters, either based on the application eg D2 or on dimensions
    Not always successful, couldn't get anything for my Kombi, but you may get lucky
    Burpengary Qld
    I have the same issue on a 2001 Td5 pls post any solution.
    Regards Ollie
    Feb 2009
    Newborough, VIC
    67.72 MB
    I think the general consensus here is, if the gaiters need replacing, it's time to replace the ball joints as well.
    2002 D2 4.6L V8 Auto SLS+2" ACE CDL Truetrac(F) Nanocom(V8 only)
    Oct 2007
    Brisbane West
    Only replace if you didnt noice and it got full of grinding paste...ie sand and mud etc...otherwise steel should and does last a lot longer than the rubber.
    Ps try a good rubber glue after cleaning first
    Burpengary Qld
    We recently changed the Swivel Ball Joints on the boys D2 V8 I would not change any swivels unless the movement in them indicates excessive wear.
    RAVE lists that SBJ replacement should only be done three times in the life of the axle housing. A fix for a damaged gaitor may lengthen the life of the SBJs
    Regards Ollie
    Dec 2010
    Brisbane Bayside
    I used bicycle inner tube ..looks ugly but keeps the crap out .
