Results 1 to 10 of 11
Thread: FPR Gaskets for 10P engines??
    Feb 2011
    Brunswick, Victoria
    Just trying to get my head around Microcat so I can order a replacement FPR gasket.
    I think I'm still getting a minor leak from the FPR after the head change and want to order a new gasket, but the correct choice doesn't appear to be exactly straight forward.
    Microcat offers two gasket choices for the 10P engine:
    MSX100080 for engines up to 10P15967B
    MSX000010 for engines after 10P15968B
    The fitting kit that came with the new head included what appears to be a MSX100080 gasket.
    If you look at Urban Panzers "how to" there is a photo midway down the page of the old and new FPR designs. The castings are a similar basic shape but there are clearly differences.
    www.discovery2.co.uk / Workshop / Fuel Pressure Regulator
    When you check the "fuel connector block" AKA FPR there are two obsoleted parts:
    MSO100010 for engines up to 10P15967B
    MSO000080 for engines after 10P15968B
    These have both been replaced by part number LR016319 which should be the newer casting design shown on UP's "how to". The "tree" of replacement parts for MSO100010 appears to indicate the correct gasket for the new regulator is MSX000010.
    I'm guessing that the gasket part numbers given in Microcat refer to vehicles fitted with the original regulator design, and that if the regulator has been replaced with the current part the MSX000010 gasket is the correct part?
    If this is the case I have the wrong gasket, which may go someway to explaining the persistent leak.
    Ok... After a bit of a dig around I came across these images which I've shamelessly pilfered:
    This is a side by side shot of new (left) and old (right) FPR designs. Oddly enough the pic shows the new reg with incorrect gasket.
    This is the MSX100080 gasket for the early regulator:
    And the MSX000010 gasket for the current design:
    I can see why my old style gasket is not working very well with the new style regulator
    Time to order the correct one I think.
    Paul
    Feb 2011
    Hobart, Tasmania, Australia
    Seems to be a common issue. The previous owner had installed the FPR onto my vehicle with the incorrect gasket too.
    Jan 2012
    Just did mine about a month ago.
    Used gasket MSX000010 on fuel block LR016319.
    REGULATOR FUEL PRESSURE ASSY - All Land Rover and Range Rover makes
    Feb 2011
    Quote Originally Posted by OffTrack View Post
    I thought there were two types of FPR.
    There is the early model type with the two hose connections and the late model type with three hose connections.
    The late type has a third hose that runs underneath the inlet manifold.
    It was my understanding that the gaskets differed depending on which type of FPR you have.
    EDIT: I note that Brit-Car refer to these as single connector and twin to distinguish them:
    Early type - FUEL BLOCK CONNECTOR SINGLE TD5 ENG > Products Available > Home > Britcar (UK) Ltd
    Later - FUEL BLOCK CONNECTOR TWIN TD5 ENGINE > Products Available > Home > Britcar (UK) Ltd
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by twr7cx View Post
    I am specifically talking about 10P engines as per the thread title which is why I've not mentioned the EU3 FPR or gasket.
    At 10P15968B the regulator design was changed, so there you have two different "single connector" fuel connector blocks each of which uses a different gasket. The "two connector" fuel connector block is basically the same casting as the later "single connector" block, with the difference being the extra drilling for the additional hose.
    FWIW the same gasket was used on all Td5 engines from 10P15968B onwards - MSX000010.
    Paul
    Feb 2011
    I did realise that you were specifically talking about 10P engines, but the point I was trying to make is that there is two types of FPR (for all TD5's in general) and two types of gaskets (for all TD5s in general), seems logical that potentially one type of gasket would be for each of the types of FPR...
    Feb 2011
    Brunswick, Victoria
    The problem is the logic isn't always clear or obvious from Microcat, and in this case the answer isn't in the gasket part information - it's buried in the OSI information for the EU2 FRP.
    The OSI tree for the early EU2 FPR is
    This basically says the original FPR for EU2 Td5's upto 10P15967B was MSO100010, which was replaced by MSO000080, which then replaced by LR016319. The "hidden detail" is the line from MSO000080 to MSX000010. This indicates the MSX000010 is the correct gasket for parts MSO000080 onwards.
    Unfortunately I hadn't looked at the OSI information for the FPR until after I'd written the original post.
    Anyway I have the MSX000010 gaskets - British Car Components had a couple in stock so I picked one up on the way home from work - and will have a chance to fit tomorrow at some stage.
    Paul
    Feb 2011
    Brunswick, Victoria
    Job done, although I must have slightly burred the bottom bolt head putting it back on last time which made removing a bit of a challenge!
    This is the offending regulator, not sure which pn# exactly but it is not the original part. The original regs are more sculpted in the casting.
    Remove the hose to the regulator by pushing in the sprung side panels on the connector and pull back on the hose. It should just slide off.
    The connector on the fuel reg is a little harder to get at. I used a flat screw driver to push the black plastic retainer back until it released and then gave the hose a gentle tug.
    This shows the design of the galleries in the current EU2 regulators.
    The correct gasket MSX000010 lines up with the galleries.
    Whereas the crush areas of the MSX100080 are clearly wrong for this regulator.
    Most of the job can be done with 1/4" ratchet, 10mm socket plus 125mm and 50mm extensions. A torque wrench is required to do the final tightening to spec. The sidchrome 1/4" extensions have about 15° off-axis movement which really helps. It's not quite as much movement as a wobble extension but is just enough to get onto the bolts with a bit of careful positioning.
    Paul
    Mar 2010
    Patagonia
    Whilst covered extensively by Paul, thought I'd throw in a 'bottom line' type post re the subject of FPR block and gasket selection.
    In a nutshell gasket selection is engine serial number driven, whereas choice of FPR block is VIN driven.
    The stuff here below I put together a long time ago, not even sure I had posted it to AULRO... here it goes then:
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by mturri View Post
    Hi Matt,
    I think it needs to be stressed that your graphic and the comment above is only true for vehicles fitted with the original FPR. Given the frequency of FPR failures I don't think it is safe to assume that is a given.
    The real bottom line is more like this.
    For the 10P the only really useful means of determining what gasket you need is looking at the regulator. If it has the flat machined face at the front facing edge you need MSX000010 regardless of the engine number or vin. The only reason you need the MSX000080 gasket is if you have an early Td5 with the original FPR.
    Paul
