Thread: 200/300Tdi engineering - NSW
    ashhhhh Guest
    Hey all,
    So im considering swapping a 200/300 motor into my Series 3 109.
    Im comfortable with the amount of info available on the actual swap but know nothing about the engineering requirements for rego in NSW.
    Has anyone been down this road and has a rego'd vehicle with this swap?
    What was required?
    I expect that the brakes would need to be upgraded and I plan to use the Roam disc kit.
    I will retain the stock gearbox and t/case but will be using an Ashcroft kit.
    Any advice appreciated.
    Ash
    Narre Warren South
    Quote Originally Posted by ashhhhh View Post
    Hey all,
    What was required?
    Ash
    Ash,
    Not sure about the situation in NSW but the recommendation was to involve an engineer at an early stage.
    Engineering a 200Tdi into a series 3
    Are you thinking of keeping the turbo ? Seems this (depending on your driving style) may shorten the life of the Series gearbox.
    200Tdi fits to the Series bellhousing easier than 300Tdi.
    Disco 200Tdi you have to move the position of the turbo if you're keeping it, Defender 200TDi harder to find.
    I stayed with the 2.4 Isuzu that was in my Series III but have yet to get it on the road so cannot comment on it's performance. Mine has a high speed transfer box.
    Isuzu C240 powered Series 3
    Disc brakes sound like a good idea, there was something about an increase in weight or power of 10% or more meant upgrading brakes.
    Best of luck,
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    ashhhhh Guest
    Thanks mate.
    Yes planning to keep the turbo, and exercise restraint.
    I spoke to someone in the industry today who suggested that most engineers are happy if the power to weight ratio is quite low, and things look factory.
    Neither of these should be difficult with this swap.
    I'll plan it all out and see what they reckon, put any into here.
    Nov 2008
    Illawarra
    The power to weight may have little impact depending upon which engine he is removing. Yes if original LR 2.25 but maybe not if common Holden 186/202 or the less common ford 4.1 conversions, or a stage 3.5 v8. But going to disks is a good idea for any drum LR . If your transplanting maybe consider grabbing the power steering as well
    ashhhhh Guest
    2.25 petrol
