Search out Jate rings, also someone does ones that attach to the standard front bumper - I'll post again if I can find a link.
 Rated recovery points?
		Hi all
I have been trying to track down a solid chasis mounted recovery hitch/point specifically designed for a deefer with no luck.
Has anyone got any contacts or know of a place to buy one?
Mick
Paddock spares in the UK or mm4x4 will sell you the bits and mm will quote u on shipping before buying where as paddocks won't
Adam
 Master
						Master
						paddocks will quote for shipping if you ask them... they got me 3 prices when I had my cylinder head shipped...
alternatively, have a look for mounting points on the chassis rail, then take measurments and sketch your own recovery point, send me your drawing and I will turn it into a .dxf file then take the dxf file to your local laser or plasma cutter and get them to cut it from 8mm mild steel. Paint it, bolt it up, job done.
My thread with similar question:
Novice recovery point/ rigging question
I fitted jate rings. I got genuine LR ones, just because. These were the widened ones so they fitted round the ARB bullbar attachment plate which also uses the same attachment location.
I also concluded that "rated" recovery points means nothing. Rated by who? If you fit them yourself then its up to you to decide if they are suitable for the intended purpose... no one else will guarantee it.
Some people argue that attaching recovery points to a bumper or bullbar is/isnt acceptable, but reality is that everybody has different set-ups and (in my case) ARB would not guarantee that my bullbar would be up to it.
I decided to remove all doubt and fit the recovery points directly to the chassis.
Just my own conclusions, hope that helps
Sam
I'm going down the terrafirma path for the puma, I don't have a bulbar yet so I found these and they look the the goods the part numbers are TFBRP for the front recovery point and TFWSRP for the rear should be on the terrafirma website ritters in Melbourne stock them not big items I'm sure postage wouldn't be an issue hope this helps
Last edited by 78RRman; 5th April 2013 at 03:53 PM. Reason: Auto spell check correction
The product that mm & paddocks sell, do they bolt to the chassis? I have 2 large eye bolts attached to bulbar, but i really want a recovery point fitted to the chassis as this is the correct location to fit one.
Thanks for info.
I'll chase these leads out.
Mick
If you don't have steering guard try this one which comes with recovery points where you can attach your shackles
http://www.aptfabrications.com.au/de...g-guard-af1020
