Results 1 to 10 of 16
Thread: 86" Rear View Mirrors
    Bunbury, WA
    Next issue before rego...
    I'm trying to sort out some rear view mirrors on Len the 86". When I acquired it, it had a central rear view mirror at the top of the windscreen, mounted through the roof of a custom truck-cab style hard top. I intend to run it as a soft top. I have seen photos of soft top 86"s that appear to have a mirror mounted on the top of the windscreen. Can anyone show me some pics of how they were mounted? Mine was originally a soft top and does not have any holes to show how a mirror might have been previously mounted there.
    Also, I take it that the standad fitment for side mirrors was on the wing top. I also note from comments on here that they vibrate madly and are generally useless. I would like to try to mount a side mirror on the upper bulkhead or windscreen frame. My vehicle has two holes in the upper section of the windscreen frame and I have noted them on several pics on the web etc. Any idea what these holes were used for? I don't intend to run with door tops. If I do, then I can mount a mirror to the door top frame where there are holes from having one there previously. Anyone got any pics of how they mounted a mirror near the windscreen frame/upper bulkhead?
    Sep 2006
    Warragul
    push bike mirrors
    Go to EPAY and look for kids push bike mirrors, the type that you see on the handlebars of kids bikes .
    They are cheap and come in various styles , and you can mount them on the W/screen pillars
    Mike
    Aug 2008
    latrobe valley victoria
    I beleave these were of a s 11 and theres copies from that Blackburn shop
    I need a new one ,the wing top ones are near worthless not so much from vibration but cause every person who walks by seems to move them
    regards mark{ps if theres 2 holes drilledon the side of the drivers side frame bout 2 inches below the top of the frame there mirror holes....
    regards mark
    2002 defender 110 , 1955 86 inch
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    my 55 107" has those holes on the drivers side of the windscreen, wondered what they were for?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Quote Originally Posted by mfc View Post
    if there's 2 holes drilled on the side of the drivers side frame bout 2 inches below the top of the frame there mirror holes....
    Those holes were for the trafficators mounting screws.
    May 2011
    Perth, West Australia
    Hi Chris,
    I had the same problem on my 80" & decided on a cheap stick on mirror in the end, which has been there nearly 2 years now & only dropped off once.
    The 107" came with wing mirrors & a bolted on interior mirror:
    This one fell through the wing just after I picked him up, hence the riveted plate underneath & extra support washers. Good for reversing but not much else.
    Interior mirror - no use for your soft top
    Another mirror I attached to the drivers door. Just secures with allen head grub screws. This and the interior mirror are the most useful.
    Do you actually need an internal rear vision mirror on vehicles of this age??
    The wife does.
    May 2011
    You don't in WA, but sure helps when you have to go down major highways at 70 KPH when everyone else wants to go 110 KPH, at least if you can see them coming you can get out of their way.
    Aug 2008
    Quote Originally Posted by wrinklearthur View Post
    damd authur ,,,now I feel moraly compeled to find traficators {it should be a notifyable disease ...s 1 ownership that is}
    ive also seen a mirror that uses 2 of the 3 bolt holes through the Blackburn landy guys
