Results 1 to 10 of 36
Thread: D2 radiator fan on - is this a symptom of doom?
    Yanchep, WA
    Hi all,
    Hoping for some help / reassurance. Over the last week I noticed that the electric radiator fan is staying on after I turn off the engine. I've read several posts where people are saying "That's good. It's supposed to do that." Etc but it hasn't been behaving like this until now, and the driving is very mild city driving in cool weather.
    My radiator overflow tank seems a little lower than normal so I will top that up ASAP. I have not observed any liquids dripping from anywhere (other than the obligatory territorial oil spots). The temp gauge seems to stay dead centre it might move by a mm but I could also be imagining that. :-/
    How can I tell how hot the engine really is. I remember reading that the temp gauge is pretty much "ok" or "wooah, miles too hot!".
    I don't have a nano com, but do these monitor real temp values? I've seen plants of digital engine saver gauges on eBay.
    I really am broke at the moment so I just need a hand diagnosing if it is panic stations time or not. Hopefully there's some stuff I can do myself to eliminate some possibilities and get to the cause.
    Thanks in advance.
    Wil.
    Nah the temp gauge is useless. Get a ScangaugeII or other meter to get an accurate reading.
    May 2009
    Tatura, Vic
    I know you said that you are broke but if you cane scrape up $150 get one of these.
    ENGINE WATCHDOG TM2, Engine Overheating Alarm, Gauge & Sensor
    They measure the temp of the steel, not the coolant, and if temp starts to climb an alarm will sound long before any engine damage.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Yanchep, WA
    Yeah I've seen the TM2 talked about. Does the nanocom cover that functionality at all from internal sensors? $150 is a good slice off a nanocom.
    I'm hoping against hope that this is just a faulty temp sensor, nut the low fluid level scares me.
    FURY Guest
    Try the relay box near the overflow tank. My V8 2000 fan was staying on after switch off i took the relay out and swap with another one problem fixed. has done it a couple of time since so i sprayed some contact cleaner on it hasn't been a problem since. good luck
    May 2009
    Tatura, Vic
    I would think the only difference between Nanocom and the temp gauge is the Nanocom will give you the actual coolant temp, but it would have to use the same sensor as your temp gauge to get the imformation.
    I agree that the $150 is close to half a Nanocom but if it saves you from cooking your TD5, need I say more.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Nov 2012
    Central Queensland
    I ordered one of these last week for $15. I have not received it yet, but it supposedly you just connect it to your OBDII port and connect it via bluetooth to your Android phone and use an app called Torque to read temperature as well as loads of other stuff.
    Apr 2012
    Orange, NSW
    I think this was discussed recently, in that they will supply basic factors, but they're more designed for newer cars.
    Paging Don Offtrack, I'm sure he'd know.
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by Trippy View Post
    I think Wil has a td5 so a generic reader wont be much use. Diesels weren't required to support OBDII until 2005, so the coverage of PIDs is very limited. Its a few years since I had a play and I couldn't say with any certainty that coolant temp is one of the available PIDs. I know that what was available wasn't that interesting - rpm, road speed, calculated load, throttle position were about it. I'd gone to the trouble of buying a kiwi wifi and it was essentially a complete waste of money for real time monitoring.
    Paul
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Wil2k View Post
    I use my nanocom as an instrument cluster permanently set up in my wee beastie and temp is on the first screen and accurate - nanocom also has a settable temp alarm for when it gets warm! $150 vs $400 - good insurance if you plan on keeping the vehicle
