Remove the other bolts, remove the flange then use vice grips on the remains of the shesred bolts.
Steve
Goal = Strip down the axle for blast and paint
All flange bolts on driver side had been loosened without issue. Passenger side went OK until two bolts sheared. See Pic. When they resisted I took my time with them - had them glowing red, used an impact driver, soaked in penetrating fluid. In the end the bolts were too tired.
The flanges need to be replaced. Any ideas for best course of action?
Steve
1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
1988 120 with rust and potential
1999 300tdi 130 single cab - "stock as bro"
2003 D2a Td5 - the boss's daily drive
 ForumSage
						ForumSage
						Heating them would make them expand and only tighter. Maybe a heat and quench with water??? May also not be a good idea??? What about a punch and hammer to give them some actual inward impact rather than just the rotational impact of an air gun....
My method for stubborn bolts has had some success recently - thought I was onto a winner.
I heat with butane and cool with pen-fluid - do this a few times.
Hammer on an impact wrench for rotational shocking.
Hammer a Drift on the bolt head for inward shocking.
Let it sit overnight.
Try again.
All else fails I increase leverage and risk bolt shear.
 Wizard
						Wizard
						A good quality ring spaner should undo those bolts , they were probly put in to tight and streached , that would weeken them . If they sheer take the hub off, then as Steve said use vice grips or if you have access to a small 10inch Stilson they will take the bolts out , If they snap at the hub they will have to be drilled out , good luck ..jimr1 ..
 Master
						Master
						Don't use vice grips. Use a quality stud extractor from snap on/mac tools etc.
and use worth rost off ice -I swear by the stuff.
It's fairly easy to replace the hub with another second hand one, but don't use any thread lock on the flange bolts stronger than screw lock.
The bolts I removed from passenger side had traces of blue thread lock and instead of a gasket on the flange it was effectively glued on with sealant. Someone set me up!
I have a record of stuffing up parts and then buying replacements to facilitate progress. It doesn't take much for me to declare something as 'stuffed'. I love an excuse to order in shiny and new. The amount of landy parts I've been sending to scrap is a sin! More sweat, less cash from now on.
All going well I'll have the studs out, strip the hub, clean it up, bit of paint, make it look like new
