Results 1 to 10 of 19
Thread: Rancho 9000s and Defenders?
    Aug 2012
    North Loburn, New Zealand
    Hi - Puma 90 has quite solid suspension and I was wondering about Rancho 9000s. Anyone got them on their truck? I see they have a new to wireless handheld adjuster for them too - sounds cool?!
    Kingston, Tassie, OZ.
    Don't do it.
    JC
    Aug 2012
    Aww bugger!
    NSW far north coast
    Don't do it.
    JC
    Double ditto, much better dampers/shockies available.
    Aug 2012
    I was thinking something adjustable - waste of time? - my road/driveway has corrugations and on the hway the suspension is too hard (yes I'm allowing for it being a SWB too).
    NSW far north coast
    Quote Originally Posted by Tikka7mm08 View Post
    If the suspension is too hard for the Hwy then it's miles too hard for corrugations.
    Rough rule of thumb, springs control ride, dampers control springs.
    What tyre pressure are you running ?
    Feb 2009
    Lower your tyre pressures. Depending on tyres, 28-32 psi generally gives an acceptable ride in a D90. I ran my original General Grabbers at 28, and run their replacement (Goodyear Wrangler MT/R Kevlar) at 31 psi.
    KarlB
    Aug 2012
    Will do - I mean its ok for highway (motorway) but around CHCH and elsewhere there are always road works etc. I'll check the pressures too thanks.
    Oct 2008
    my 90 had 9000s when i got it. they are rubbish
    I now have 7100 billies to put on
    n plus one Guest
    Bilstiens - the more the merrier too. I'm running six at the moment and will be fitting two more soon...
