Results 1 to 10 of 19
Thread: LT230
    Oct 2012
    FNQ
    LT230
    While fitting the Quaife TBD I did a few other mods .As well as the oil mods as posted by Bush 65 I bored the rear output housing 6 mm deeper and fitted a double row bearing and shortened the spacer between the speedo gear and
    bearing.
    more tomorrow
    AM
    Oct 2012
    FNQ
    Next was the notorius intermediate gear leak the shaft was set up located in a
    unworn section and centre determined the case then bored to 1.400" with a recess for a flange,A bush of 4140 was turned up and pressed in with a bit of
    gasket eliminator round the flange.the bush then finished to size [.The collapsible spacer more suitable for a dunny roll than a TC] The inter gear was set up on the shaft with old trued up spacer the end float measured and a
    solid 4140 solid spacer turned up with allowance for preload
    AM
    you are putting some very nice machinery to good use there AM. well done and keep up the good work.
    Judo's Avatar
    Judo is offline ChatterBox Silver Subscriber
    Feb 2012
    Parkdale, Melbourne
    The kind of work I can only dream about....
    ...and read on AULRO.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    nice work. for info, the later cases, TD5 onwards dont have the collapsible spacer, they have a solid spacer like yours
    Oct 2012
    FNQ
    I did not know Do they supply different spacers ?or hopefully don`t use shims setting preload is a breeze on the bench I suspect the collapsible spacer contributes to case wear
    AM
    I agree re the case wear. yes there are different sizes available as far as I know.
    Rgds
    Pete
    Oct 2012
    FNQ
    Next the front output flange was replaced with a 9"ford yoke same spline about 20 mm the area with no spline turned off and a mud shield fitted
    The yoke uses the larger Landy universal 1310 series or a 1350 series could
    be used for more articulation or HP
    Oct 2012
    FNQ
    Thanks for the interest fellas makes writing it up worthwhile .A bit more. A
    disk park brake was bought and fitted with a small mod .Mounted to the back
    of the flange instead off the front brings it closer to the case about 20mm.
    The modded 1350 yoke was then thru bolted and a special nut machined.
    Pictures show custom PTO hydraulic pump Finned extended sump and disc brake with drive flange. Just separate levers for HY--LOW Diff lock and PTO
    to be done
    Thanks AM
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Very nice work. What will you be using the hydraulic pump for?
