Originally Posted by
mools
Hi all,
I recently got some upgraded Ashcroft goodies; CV's, Half shafts (axels) and drive flanges and want to fit them to my 2006 110. While I'm at it I want to go to oil lubed hubs too.
I consider myself to be reasonably practical but I've had a look around this topic for a short while but can't quite get the concise info. I need. Lots of useful stuff out there but I want to know exactly what I'm in for before I strip down a corner to find I don't have what I need to complete the job. Once-upon-a-time I may have been tempted to give this job to someone else but I think I really should be able to strip and build the hubs myself I'm just laking the confidence on a couple of items and don't want to be doing this again and again - once and properly. In return for good advise from the forum I'll write it up, with pictures, in to a step by step article for anyone else in the future.
The diagrams below are from the RAVE manual for a 300 tdi, I couldn't find any that where more specific but as far as I can tell they should be nearly correct, please point out if I'm wrong about this. So here are my questions....
Firstly for the rear....
It appears there are just two seals in there. So...
1) Aa far as I can tell outer hub / axle shaft seal (8 in the diagram above) is removed and not replaced to allow oil to migrate from the diff housing is this correct? If not then what is done here?
Correct - removed
2) What happens to the inner hub seal (7 above). Is it
a) left alone,
b) upgraded to a higher spec oil seal (if so part no.?) or
c) Just pulled out and disposed of.
Upgraded to RTC3511 (unless there's an even better one that I'm not aware of
3) Have I overlooked anything?
Now for the front:
4) Firstly can you convert later style (no swivel housing drain plus) type assemblies to be oil fed? Looking at the diagram (below) I'm a little sceptical that this can be fed adequately from the diff housing, however, if it can then there are 3 seals...
Yes
5) Axel shaft seal (8 in the above diagram) just junk and not replace? or what? Ashcroft do a larger seal (refered to as 'the oil seal fitted to the swivel ball' on their web site) for the larger shaft. But if going for oil lubed hubs is this seal just dispensed with anyway?
You have a choice here. If you remove it you have one compartment across the entire axle. If you leave it in your swivels and wheel bearings are separate from the diff housing itself. I run the latter option
6) The CV shaft seal (No. 23 above) located in the stub axel. Stay, go or upgraded?
Removed to allow oil to get to the wheel bearings
7) Part 7 above, inner and outer hub seals what happens with these? Junked or upgraded? If upgraded whats the part no.?
Upgraded to RTC3511 same as the back
an additional lubrication question....
8) What is the best way to pack the CV and bearings if going to oil fed? Do they require pre packing with grease? and if so do you need to re pack them periodically?
I pre-pack wheel bearings on initial fitment. No requirement to repack unless you have removed/cleaned them for some reason, in which case I treat them as new and repack. When I fitted my upgraded CV's from Rovertracks, Keith advised me to do an initial packing with CV grease. Not sure if Ashcrofts recommend similar
Now, I think that's all I need to know. So if you can help out with some concise and knowledgeable answers I'd be most appreciative.
Thank very much,
Ian.
Oh, and if the diagrams are too small just double click to open a larger one.
Answers in red above.
You don't want to fill the swivel completely with oil. There should be an area visible on fhe forward side of the swivel casting where the fill plug went in earlier models. I used a bamboo skewer as a dipstick to fill with oil to slightly above that level. Re-check in a week or so.
Dougal's zip-tie suggestion above isn't applicable if you're running the screw on cap style upgraded flanges.
Steve
1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
1988 120 with rust and potential
1999 300tdi 130 single cab - "stock as bro"
2003 D2a Td5 - the boss's daily drive
