Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
Thread: Sound Deadening
    Apr 2011
    Adelaide
    Sound Deadening
    Hi all
    I'm going to sound deaden the 130 td5 this long weekend. Looking at using Dynamat Extreme on floors and doors. Has anyone undertaken this? just looking for a few tips and to hear about the end result
    cheers ben
    Apr 2007
    Northern Hunter Valley,Dungog Shire
    Hi Ben,there are a number of threads on this topic and all you need to do is "search". They all report worthwhile gains in both sound and heat reduction. Cheers, 130man.
    Jan 2010
    Do the roof as well...
    It's amazing how much noise is from that roof!
    Apr 2007
    Ipswich QLD
    Hey Ben, I've used Dynamat on the County. Excellent product and it worked, but expensive. Definitely do the roof, makes a big difference. I also used bostik 8152 sound deadening sheets, a lot cheaper. Make sure you understand the difference between deadening the panels and insulating the sound, otherwise you will not get the result your looking for.
    Apr 2007
    Ipswich QLD
    Oh, and the search function on this forum is hopeless
    Apr 2010
    I got a real cheap rubber solution, picked it all up from work for nowt.
    Seriously though, if it bothers you good on ya for trying to sort it out.
    Ian
    Aussie Expat in NZ
    Quote Originally Posted by Ben7 View Post
    Hi all
    cheers ben
    G'Day Ben,
    Did this a few years ago using Dynamat - used 3 extreme packs IIRC. Make sure you seal everything up really well before you start, no little holes, gaps or anything - anywhere.
    If you havn't already, get the Puma style under door seals - they will make a big difference and don't cost much. It is also worth replacing all the little rubber gromits around the wires in the firewall as once they start to break down they will not insulate sound at all.
    Without doing the above, you won't get the most out of the (significant) investment in dynamat.
    The second thing that is really important is that dynamat itself will make a big difference in that it stops the panels from resonating noise and heat, but it doesn't absorb any noise in itself.
    For this you neat a Vinyl or Butyl layered matt. It is like a very heavy closed cell foam matting.
    Wheelers Hill, Melbourne
    The last Landie I did the roof & agree!! Next time I will buy a couple of yoga mats from Big W - they are only $12.00 each - about the area of a camp bed- and soft foam about 10mm thick- wont burn either, a much cheaper option.
    Feb 2009
    Hi all
    cheers ben
    You will need more than a long weekend unless you know exactly how much you need and have a cutting list - and depending on how insane you want to go.
    I am bang smack in the middle of doing my 110 now - I reckon I have spent over $3k easy. I did just the dynamat on the floors with 1 dynamat extreem megapack and stopped when I ran out. Basicly did very little and I also want to stop heat so Am doing it properly or as best as I can. If i remember i will post some pix, doing the LHF door today.
    Oh and do your doors last and use your offcuts. Dynamat isn't a barrier so you just need to cover the resonating metal. The doors are odd shapes and sizes perfect for offcuts
