Results 1 to 10 of 11
Thread: Door Light
    DWN06 Guest
    Door Light
    Hi All
    can anyone tell me where i can get into wiring loom for the door light for a full 12v as the loom in the door trim only gives me 1.5v?
    99.87 MB
    Without looking at RAVE, you may find its only 1.5v because the switch talks to the BCU rather than actually powering the light like it may do on an older vehicle.
    Slunnie
    DWN06 Guest
    is there anyway of getting 12v to work from the door light or better using head lights to get 12v?
    What are you looking to achieve?
    DWN06 Guest
    Well i got a gift that puts the LR logo on ground when door opens fitting suggest to wire to door light for when opening the door
    99.87 MB
    You may be better off picking up power at the light in that case and running it to the gizmo.
    Slunnie
    DWN06 Guest
    thanks
    well give that go.
    r
    Guy
    schuy1 Guest
    Yes the SLABS ECU is the controlling force. The door switches are located in the door latching/Locking mechanisms. So you will have to use the actual light power wire as your source . So that your puddle lights operate in conjuction with the interior/entry . You really need the RAVE Electrical library to follow it correctly
    Cheers Scott
    DWN06 Guest
    where can i get the RAVE from?
    R
    Guy
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by schuy1 View Post
    Cheers Scott
    BCU not SLABS unless you have a very odd D2
