Results 1 to 10 of 38
Thread: Rear wheel carrier
    Oct 2010
    Caloundra
    Rear wheel carrier
    Anyone know if the D1 and D2 real wheel carriers are the same?
    Local tyre shop left it to the apprentice to put the spare wheel back on - with a air gun I'm assuming, crossing some threads in the meantime. I couldn't get it off , and it took them an impact air gun to get it off, leaving two bolts and nuts buggered, they're going to replace it, and I'd be happy with a second hand one if available. Will a D1 or D2a fit interchangeably?
    Apr 2012
    Orange, NSW
    Why would you airgun on the spare.......
    Wheels maybe, but the spare?
    If they're going to replace it, just get a D2 one.
    Get it inverted while you're at it so you can put a larger tyre on the rear
    EDIT:
    Here's a link to a D2 and then a D1 carrier.
    Looks pretty much identical to me, perhaps there are subtle differences.
    http://www.ebay.com.au/itm/LAND-ROVE...ee7d3c8&_uhb=1
    http://www.ebay.com.au/itm/LAND-ROVE...1ad4345&_uhb=1
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    sheerluck Guest
    They have separate part numbers, presumably because the bolt spacing is quite different on the D2 compared to the D1.
    Looks like the rest of the metalwork is quite similar, though. However, I'd make them pay for a proper new one.
    Feb 2011
    Hobart, Tasmania, Australia
    Quote Originally Posted by sheerluck View Post
    There's no reason it needs to be new, the one that they broke wasn't new.
    It sounds like the tyre shop made a mistake and have owned up to it and are doing the right thing. There is no point in pushing it further than it needs to be, if they're replacing a broken used one with a good condition second hand one, that seems perfectly reasonable. Forcing them to supply a new one, may just mean that this time you get a brand new one, but next time (and it might be someone else completely), they'll be ****** and deny that it happened at their shop because of how much it cost them last time. If they're being pleasant and helpful about it and have agreed to resolve it in an acceptable mean, why push it, there's many other shops that would just be ****** about it.
    But the above is just my opinion.
    Apr 2012
    Orange, NSW
    Think about it though.
    Spares may have to be freighted from the other side of the country, might be private seller, and you have no idea on its condition and lets face it. A spare wheel and tyre isn't a light item by any stretch of the imagination, the item might be stuffed.
    As opposed to going to the local landy dealership or parts place, which will be a registered business (which makes things easier, I've had to deal with replacing items damaged at a tyre store, and they said it's much easier to have a formal receipt from a business, or for them to ring up and say how much). You've also got a much better chance of being able to claim warranty in the event that it's a dud.
    I'd be going for a new one.
    Jul 2007
    Quote Originally Posted by Pinelli View Post
    No they will be different given that the diameter of the circle the bolt holes are on the wheels is different. I think even the thread size of the studs is different. Easiest fix is probably a replacement of the studs, I have not looked to see how the studs are attached but it had to be assembled some how.
    Quote Originally Posted by benji View Post
    Maybe we're expecting too much out of what really is a smallish motor allready pushing 2 tonnes. Just because it's a v8 doesn't mean it's powerfull.
    One answer REV IT BABY REV IT!!!
    Dec 2012
    Hi there,
    I just bought my D2 and it didn't have nuts for the spare wheel carrier. A friend of mine who has about 5 D1s in his own private graveyard had some so thinking they would fit I grabbed them. Unfortunately they are much larger on the D1 than on the D2.
    Haven't been able to source any nuts for my D2 yet but once I do I can let you know also.
    Tony
    Apr 2012
    Orange, NSW
    Quote Originally Posted by oxley2903 View Post
    Have you put the CDL back in?
    sheerluck Guest
    Quote Originally Posted by twr7cx View Post
    There's no reason it needs to be new, the one that they broke wasn't new........
    In my post I didn't actually mean a brand spanking new item, I think fingers got ahead of brain a little.
    The impression I got from the OP's post was that the company concerned were looking to cobble something together, rather than just replace the carrier.
    My thought (which my fingers didn't necessarily manage to convey properly) was that just getting to go to a breaker, who often give a limited warranty on their parts, and get the right part, and bolt it on.
    That to me would seem pretty fair.
    Jul 2007
    Hi there,
    Tony
    M14 X 1.5, I think you will find the later commodores use the same stud/wheel nut thread size as the D2. However if your spare is an alloy you will also have to match the hole size in the wheel which for D2s is quite large.
