Assuming this is going into a 86".
Gearbox bell housing needs to be swapped, the series one 2.0 ltr petrol and the series two 2.6 ltr six cylinder have the top bolt holes either side of the top centre, whereas the 2.25 ltr four cylinder has a single bolt hole at the top centre.
side engine mount brackets are the same.Engine mounts?
you can use the same clutch plate and pressure plate.Will the si bell housing mate up retaining the clutch?
The mechanical series one clutch linkage will fit into the series two bell housing.
Tip the front of the engine up by using a pair of rubber engine mounts from a petrol F engine FJ40 Toyota, that gives a bit more room between the top of the diff housing and the front pulley, but you can still get the crank handle in.Length? Cooling fan?
You can use the fan from either engine, but watch the clearance between the tips of the fan and the radiator cowling.
The exhaust pipe needs to be replaced with the engine section for a series two and bit of plumbing for the fuel line, run that line through some garden hose stops vapour locks occurring.
You wont need the electric fuel pump but don't lose it as they are getting scarce.
