One of the out of curiosity projects I did was to compare the price of getting a provided center put into a carrier (quote only) with new carrier bearings and new pinion bearings with the stated assumption that the pinion and crown wheel were sound against a from scratch DIY.
It was cheaper to go and buy the workshop manual, the bearings and a small stack of shims, a DTI + mount, a vernier, some files and a block of steel then make the height block and build the diff.
IF you dont have one already, buy the Rave CD the instructions for the diff are in there.
