Results 1 to 10 of 11
Thread: Weight of an alloy rim and tyre?
    Oct 2011
    Fremantle WA
    To save me taking my spare off to weigh, can anyone tell me the approximate weight of a 16" alloy rim plus tyre? I'm trying to get a set of 5 transported from Adelaide to Fremantle. I'm assuming compressed air won't make much difference if the tyres haven't gone flat in the interim!!!
    Cheers Gavin
    Avoca Beach
    Range Rover classic ones with 205x16 tyres weigh 23.5 Kg so probably about 25Kg. so freight will probably go on dimensions.
    Regards Philip A
    Aug 2009
    Lara, VIC
    I've not weighed mine, but I've changed a couple recently. I think a reasonable weight would be around 20-25kg per wheel if they are standard tyres.
    Factoring in the weight of a pallet, assuming they'll be strapped to one, 200kg for the lot would be in the ballpark I reckon.
    Try GKR Transport or WA Freightlines for the transport side of things.
    Feb 2011
    Hobart, Tasmania, Australia
    Try e-go too I think ego.com.au is the address. They're a division of HUnter Express.
    I've got 5 18" tyres coming from tirerack at the moment and the shipping bill lists it as 84kg. That's rubber only.
    Melbourne, Australia
    Quote Originally Posted by gavinwibrow View Post
    Cheers Gavin
    20-25 kg sounded light to me and I had 43 kg in my head - so, I checked and weighed a wheel (265/75 tyres on 8" alloy rim)
    Try 47 kgs.
    Franz
    Avoca Beach
    Are you sure your scales are correct?
    According to my admitted bathroom scales a 750x16 on a Toyota split rim only weighs 45KG.
    And I weighed a 245x75x16LT BFG AT on a RRC alloy at 23.5Kg.And RRC alloys are HEAVY .
    I also measured the alloy at 10Kg vs a steel Disco 1 wheel at 13Kg.
    Regards Philip A
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Franz View Post
    Try 47 kgs.
    Franz
    Many thanks Franz - I'm not surprised - heavy to lift!! In light of other comments I'll measure my spare rim which is an 8" six spoke - effectively a range rover lend I understand.
    Regards Philip A
    I also used bathroom scales and I'm reasonably sure they're correct. As I said, I had 43kg in the back of my head from when I weighed them on decent scales. 265/75 MT's will weigh a fair bit more than 245 AT's.
    Avoca Beach
    Tirerack site lists a 265 75 16 LT BFG ATKO as 24Kg , so given maybe 10-15Kg for a wheel , the weight lies somewhere between our two extremes methinks.
    Any way I know they are bloody heavy to lift onto the rear carrier on my D2.
    Regards Philip A
