Those 90 series shock are too short if you go higher than standard, even the ones they quote are for a +40-60mm lift.
From memory even the longer ones only give you 5mm of travel!!!!!!
I raised this with them some time ago and they were not interested! Shame really as I wanted a set of the 90 series for the 110.
The 80 series are long enough and would more than likely be fine for your needs.
King springs are excellent.
Sent using Forum Runner
