Results 1 to 10 of 24
Thread: Drilled and Slotted Rotors
    Ringwood, Vic
    Whilst having my D2a serviced a few weeks ago it was noted that my front rotors were a bit sus. Went with the AMV recommendation to replace with drilled and slotted ones and WOW! My brakes were always good, and I'd always thought this upgrade was a bit of a **** but I'm a convert!
    Stopping is stronger than ever.
    Going to go for drilled rears at the next service.
    Oh yes, they were only $174/pair.....plus new pads.
    D4 SDV6, a blank canvas
    Yep,
    Did the same and fitted TRW pads on the front. Very happy.
    Land Rover - The leader in chasis rust protection with leading edge oil application system.
    2000 Discovery TD5 - ACE. 2" Lift and Bloody big lights
    2016 Discovery D4 SDV6 HSE ARB Bar, lights and winch. Wow
    Apr 2012
    Orange, NSW
    Just a heads up, Drilled rotors can cause stress fractures around the holes, not sure how common it is but it does happen.
    Hope you enjoy them, about to go through the same process myself
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    I think slotted rotors are a good thing and do make a difference. However I am not convinced on the drilled part
    As Mr Muppet said, they are prone to stress fractures but on a 4wd they also fill up with mud very quickly.
    The TRW pads made more difference than anything to my brakes, they are great.
    Feb 2011
    Hobart, Tasmania, Australia
    Cross drilled rotors are generally only suitable for a street road car. Most track cars will avoid them due to the fractures that occur. Likewise on 4WD's going off road there can often be issues with stuff getting in there.
    RDA have taken an interesting approach to this. Instead of using drilled out holes they use a combination of the slots and dimples, thus retaining more of the strength. I have these on the rear of my D2a in the gold coating and have a set in the garage for the front. The gold coating helps to prevent corrosion which can be an issue with how often my vehicle is in salt water.
    Feb 2011
    Brunswick, Victoria
    I have DBA T2 slotted discs all round on mine with LR pads. I like them a lot but have noticed that they are a bit noisy under heavy braking. From what I've read this is a pretty common trait of slotted rotors.
    Brakes Direct - DBA528S DBA Street Series T2 Slotted Brake Rotor
    The fronts have the "kangaroo paw venting".
    [ame=http://www.youtube.com/watch?v=8PzWFn6lGBs]DBA Kangaroo Paw Disc Rotor Ventilation Design - YouTube[/ame]
    Paul
    99.87 MB
    X2 for the dba slots, they are excellent and are quiet for me, these work very well with Bendix pads.
    Slunnie
    Williams West Aust
    About to upgrade to slotted/cross drilled rotors all round this weekend.
    Any pitfalls to watch for or any tips greatly appreciated.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    99.87 MB
    Andrew
    It's all straight forward, but I would recommend not getting drilled dur to cracking of the rotor. If you really want that type of thing look at dimpled instead.
    Slunnie
    Williams West Aust
    Already here and ready to fit Slunnie.
    Isnt the cracking caused by quenching of the red hot rotor in water???
    Unlikely to happen unless one drives like a rally star off-road.
    Not a hard on the brakes man myself,was told my rotors were close to being needing replacing when I first bought the D2,only needing to do it now at around 80000ks 7 years later.
    The most wear is since chiping/intercooler/exhaust modifications
    Love that TC light on the dash
    Andrew
