Results 1 to 8 of 8
Thread: Series Diff Overhaul
    Narre Warren South
    I have a spare diff I thought I'd overhaul for 'stock'. I knew the outer pinion shaft bearing was rusted but I thought I'd be able to salvage the rest.
    Stripped it last night and all the bearings are badly damaged due to rust (there was a rust hole in the diff cover) but the crownwheel & pinion are OK.
    Timken crownwheel taper rollers $16 for the outer race $25 for the inner race.
    Timken inner pinion shaft bearing $33 for the outer race and $45 for the inner race.
    I already have a Timken outer pinion shaft bearing.
    So $145 for the other 3 bearings....... almost cheaper to buy a 'parts car' and hope that one of the diffs is OK.
    I may proceed with no-name bearings.
    I'm hoping to measure the height of the old inner pinion shaft bearing and compare with the new one. I can then measure the shim fitted and add or subtract the difference in the bearing height of the replacement bearing and re-shim.
    Any thoughts on this ?
    It does assume that it was set correctly to start with plus I'd 'blue' the gears and check afterwards anyway.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    if you want to go that way I've probably got a couple of series diffs that are going to come up as spares.
    PM me if you want an option to buy once I start stripping the diff housings down.
    Narre Warren South
    Thanks Dave.
    I'm onto a S2 LWB parts vehicle, just have to get it past SWMBO.
    Went to view it a few weeks ago, opened the tailgate and the hinges ripped out of the rear crossmember. Front wing damaged where a branch has dropped on it.
    Lots of usable parts (tub, 1 wing, cab, motor, gearbox etc.), hopefully it has a usable diff.
    I'll see if he'll let me part it out where it is, if not I need to negotiate with SWMBO.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    WA
    If you go down the rebuild route, check the thread on the pinion carefully and don't overtighten the pinion nut. I have seen a few diffs fail that way.
    Narre Warren South
    The diff I have from a Series III has '49T75' stamped on the outside edge it's 4.7:1 ratio.
    Another diff I was given has '19T73' stamped on the outside edge, it's 3.54:1 ratio.
    Do the numbers on the diff give the build date ?
    I've decided to get some no-name bearings and re-assemble the 4.7:1 diff. Never done one before but doesn't look difficult. I'll dust off my magnetic dial gauge base & dial gauge for checking the backlash and find a spring balance for checking the pre-load.
    Toyota Tundra diff rebuild on YouTube
    [ame=http://www.youtube.com/watch?v=dAqAqODmcj4]Differential Ring and Pinion Gear Setup - YouTube[/ame]
    I love the diff holding fixture, difficult to justify for a one-off though.
    The Toyota has a pre-load on the crownwheel bearings (in the Land Rover manual it just states 'zero endfloat'). Interesting how the guy measures the crownwheel bearing pre-load from the pinion end.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narre Warren South
    I've started the diff overhaul. Pictures here http://www.aulro.com/afvb/showthread...46#post1917746 post #173
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Dec 2009
    Williamstown, Barossa, SA
    Have two SWB's both with 4.7's in them if you get stuck. Will be running 3.54's.
    Narre Warren South
    Quote Originally Posted by Sitec View Post
    Thanks but this is just a spare. I still have another complete spare axle to check out and a spares car to collect (could be 2 more diff centres that are OK).
    Just wanted to be in the position of having one that is a known quantity.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
