Results 1 to 10 of 26
Thread: D3 REAR END BOUNCING AFTER SPEED HUMPS
    Jul 2010
    Terrigal sometimes, but mostly everywhere else
    Hi All.
    Our D3 has non air suspension and is raised 40mm. It has just started to develop bouncing in the rear after going over those pedestrian speed humps at crossings and so on.
    Shocks are possibly 100k old. First I thought springs, but then
    I thought shocks, what does the forum think?
    Also, if the springs are 40mm higher than standard, do I require a special/longer shock? and which brand of shock/springs would you all recommend. I will be installing them myself.
    Regards,
    Gm
    1991 2 door Disco (current)
    2012 Puma ute
    2007 D3
    1976 2 door RR
    1977 2 door RR
    1972 FORD XY 4X4
    + 70 other vehicles and trucks
    Bangor, NSW
    Hi GM,
    +1 on rear shocks.
    IIRC, Dobinsons are the preferred brand for D3 coilers.
    Mar 2007
    South Arm, Tasmania
    Definitely the shocks are buggered. Probably nothing wrong with the springs at all (if the vehicle is still sitting level).
    Can't help with what to replace them with though.
    Cheers .........
    BMKAL
    Nov 2010
    Adelaide
    Dampers (shocks). I've got mates (albeit high performance vehicles) who replace dapers at 50K, if it wasn't for the cost they'd do it with each set of tyres! Bit over the top for me, I change 'em at 100K.
    Jul 2009
    Quote Originally Posted by theresanothersteve View Post
    Have to agree with your mates, most shocks are lucky to still be working anywhere near their best after 50k.
    The thing is they go off gradually so we don't tend to notice how bad they have become until they are completely stuffed.
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    May 2010
    melbourne
    Hi GM
    I have the same set up as yourself, coil sprung with a 50mm lift. Would be very interested to know the options for replacement shockers, especially with a 50mm lift. My D3 has 167000kms on the clock and am assuming on the original shockers. It's due for a service soon and I'm thinking of getting the shocks replaced.
    Any suggestions forum users? Would air spring shocks be the same. I'm guessing as the air sprung D3 can raise up to 100mm??? the same shocks for a lifted coil sprung D3 should be fine.
    Cheers Andrew
    Sydney, Australia
    There was an issue with the early King Springs overextending the shocks, not sure which ones though.
    NSW SW Slopes
    Quote Originally Posted by TerryO View Post
    I totally agree and changed the last ones under 60K.
    Apr 2012
    brisbane
    Hi Jonesy63
    I have a D3 coiler & was thinking of lifting it with a set of springs & shocks. Have you had any experience with the Dobinson Springs & shocks? Would it be better to use King springs & Dobinson shocks or all Dobinson, or maybe some other brand shocks? The car has 67 000km & I will be towing a 1500 kg off road camper.
    Murray
    Feb 2013
    st ives
    Have to agree with this statement ....my rear shocks have just been replaced (at 50K ) and they seemed to just go off suddenly ie were stuffed .....rear end bouncing around after a bump and very harse ride
    QUESTION ....does the air suspension also loose some of its effect over time leading to a harder ride or are the shocks alone what give the smooth ride
    My vechicle still seems a little harder than it was when it was new even with the new rear shocks .....could that be to do with the airsuspension or something else
