Thread: TDI engine mount air compressor
    Sep 2011
    Sydney NSW
    Seeking some advice on how to, or if it is possible to mount an air conditioner compressor to a 300tdi discovery to pump up my air tank (from a p38) or is there a better alternative? the air tank is for future lockers, pumping up tyres and air horn.
    thanks
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I believe its simple enough, very similar to aircon compressor with clutch, just need to mount it suitably to run off your fan belt.....
    Jul 2007
    Yes as said, get it mounted and driven off the belt. Then you need to determine if you are going to oil it via a connection to the crankcase gases or not, if your going to separate the oil and water post compressor, cooling the air if it gets too hot so it doesn't melt your hoses. Unless your going to run air tools, your not going to need a real big tank.
    I have a truck air brake cylinder which helps the electric compressor catch up as your airing up.
    Quote Originally Posted by benji View Post
    Maybe we're expecting too much out of what really is a smallish motor allready pushing 2 tonnes. Just because it's a v8 doesn't mean it's powerfull.
    One answer REV IT BABY REV IT!!!
    Thats in the works on SWMBO's vehicle ATM (Since I've got to pull out the freshly new cooling systemd engine out to replace the clutch I wasnt told was also dodgy)
    I'm looking at welding the adapter plates of 2 TDi 300s together.
    If shes not lucky it'll get a compressor via means of Cut aircon lines and splice on air fittings.
    Last edited by Blknight.aus; 18th May 2013 at 01:14 PM. Reason: that english was so bad even a spanglish writer would have been ashamed.
    Nanny state UK...
    Depends if you want air-con or not...
    As has already been said, the usual place it to use a modified air-con compressor & associated bits to drive it.
    M
