The ones I have seen have the horn hanging down from the underside of the bonnet.
Cheers, Mick.
Can anyone show me a pic or describe where the horn goes on an 86".
The books just say the front crossmember but not where or how.
Thanks.
Keith
Cheers, Mick.
1968 SIIa SWB
1978 SIII Game SWB
2002 130 Crew Cab HCPU
 Master
						Master
						Hi Keith
Don't take any notice of any of them !
If you look on top of the plate that blanks off the hole where the steering relay would be if it was built LHD, see if it has a threaded hole in the plate.
That's where the horn was on all the 86" Landy's that I have had anything to do with and the horn was the type that had the vibrating disk, without any trumpet.
The sound of that horn is the true voice of a 86".
 Master
						Master
						Thats good, I wondered what that hole was for.
This is what I call the 4 hole 86". (Holes for tow plate)
The first chassis I was going to use,( 6 hole), also has the bolt hole in the relay blank plate but another 6 hole 86" chassis has not so I wonder where that horn goes.
 Master
						Master
						I think most people are right as there are differences across the 86" depending on production. I have been cannibalising 2 then 3, 86" to make one good one. On a very original 86 the horn was bolted to the underside of the radiator support panel. The others have the hole in the blanked off relay and were mounted to the chassis.
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
