Results 1 to 10 of 36
Thread: Simplest Dual Battery Setup
    Sep 2011
    Sydney NSW
    I have looked at previous posts, and am now completely confused on what to do. I have 96 discovery, soon to carry a winch and already has a fridge. I am wondering what is the simplest and most beneficial dual battery system? What wiring kits are needed, and battery type/brand is recommended? Will the fridge be on the same battery as the winch, How do I connect it, does it run to the alternator also? will my alternator need to be upgraded?
    Very new to the dual battery world, and help would be appreciated.
    Torres Straits
    1/ Install second battery.
    2/ -ve terminal to a good chassis earthpoint.
    3/ +ve terminal to Primary battery +ve with heavy cable.
    Use a multimeter to monitor battery vs fridge run time.
    voila
    simple and probably best for winching too...
    S
    Jul 2009
    Hobart
    Hi,
    Get a deep cycle battery for your winch/fridge/camping needs so you won't ever accidently discharge your starting battery.
    The deep cycle battery can be directly connected to your starting battery through a device like
    Traxide sell these, and are a good crew to deal with.
    I bought a kit from them to put in my second battery and found them very helpful indeed when I ran into a problem of my own making.
    usual disclaimers here - just a happy customer
    Nundle
    Install second battery, same as starter and connect both through a 3 way marine switch. Cheap and effective.
    Works for me.
    Numpty
    REMLR No 143
    Scarborough QLD
    I fitted a dual battery to my old D1. I used a heavy duty solenoid to connect the positive leads and a chasis earth. The solenoid was activated by the alternator charge light. This meant the solenoid would not engage until the engine was running. If your main battery goes flat just run a lead from the second battery to the solenoid terminal to connect the two together.
    HTH
    Ivan
    Nov 2008
    seaham (gods country) nsw
    Quote Originally Posted by Ivan View Post
    HTH
    Ivan
    I have a similar thing on my classic, except I have a relay that connects the two positives together when the ignition is on. Run my fridge and other auxiliaries off the second battery (which runs them all the time) and all the normal stuff (cd player lights etc.) runs off the original battery. it cost about 50 bucks for wiring, relay, connectors and cig plugs, plus a secondary battery.
    Tangus
    1925 - Trojan Utility
    1973 - jaguar XJ6
    1980 - Series 3 FFR
    1980 - Series 3 GS
    1998 - 300tdi 130
    Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
    Feb 2012
    Parkdale, Melbourne
    Keep in mind:
    fridge = deep cycle battery (low current / long time)
    winch = cranking battery (high current / short time)
    A marine type battery can do both. If your second battery will be powering both winch and fridge, I would recommend a marine type battery.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    lokka Guest
    I run a SLA 100AH battery in the back alongside the fridge it has a set of cables connected to the main via a 60Amp relay which is locked on once the ignition is on it only runs the fridge and i have an extra socket for other bits if needed in the back its a non perm set up and when im not using the fridge the battery and fridge are removed and the cable that conects the battery tucked away and the fuse down at the relay end is removed so line to back is neutral when not in use .
    I am yet to fit a second batt up front but it will happen soon enough and i will probably just use a similar set up to what i have now tho go for a 200Amp relay to join the 2 batts up front
    May 2006
    Woolgoolga
    Just buy the TRAXIDE US 160(?), great kit, will run your winch, Australian made, and great to deal with. Plus Tim is a member on here.
    May 2002
    Heathcote (in "The Shire")
    Pair of batteries (don't necessarily need to be the same) connected with a marine isolator.
    The reason I say don't need to be same is that in my situation I don't think I have ever run them in parallel.
    Have had this system installed for the last 30 years without a failure.
    Martyn
