Results 1 to 3 of 3
Thread: Rear springs, Front bolt
    Sandgate, Brisbane
    Do I really have to remove the fuel tanks?
    What's involved with that?
    Do I have to remove it completely or can I move it out of the way with the lines still attached?
    Tears over, challenge accepted :-)
    Narre Warren South
    Quote Originally Posted by Cannon View Post
    Unfortunately you have to drop the tank(s).
    Disconnect fuel line(s), disconnect sender, unclamp filler and breather hoses, undo bolts & lower on a trolley jack.
    I did my SIII recently and considered putting the bolt in the other way round. When I looked at the tank there was a depression where someone had done this in the past and it rubbed against the tank.
    If you put a dent in the right spot you might be able to fit the bolt the other way round when you re-fit the tank (but that doesn't help you at the moment).
    best of luck.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Sandgate, Brisbane
    Thanks mate
    When I saw it this morning I considered that I spin the bolts about but as you've stated, they will hit the tanks.
    At least I've got a disconnected one to practice on first
