Results 1 to 10 of 12
Thread: Radiator hoses
    Queensland
    Radiator hoses
    Nothing in the "Sticky" but I remember someone was going to do a list.
    What are you all using for hoses now or is it still a case of cut and shut whatever we can find?
    Keith
    australia
    Quote Originally Posted by 123rover50 View Post
    Keith
    dusnsfold have stock in jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Narre Warren South
    Keith
    4Wheel Drives in Melbourne usually carry them.
    If you wander into Supercrap with an old hose you can usually match them up. I found a hose the other day that could be cut down for the top radiator hose I'll see if it still has the number on it.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Queensland
    Quote Originally Posted by russellrovers View Post
    I was hoping to buy locally without that freight that is worth more than the hose
    May 2009
    I think the bottom or top hose still carry's a current number. Might be worth giving Fwd Yeerongpilly Brisbane and MR Automotive a call they might be able to lookup the old numbers.
    Oct 2010
    I found a Toyota Corolla hose that actually cut down to do all three required hoses - radiator top and bottom and the thermostat bypass hose. I knew I should have written the part number down.
    Gosnells
    How about this for an idea... Stop worrying about trying to find a hose - or part of a hose that can be trimmed down to suit... instead, utilise lengths of straight metal pipe and use appropriate bendy bits for...the bends. Ideally, the pipe should be flared (like a bought one!) and I'm sure there is a plumber's gadget that makes the shape, - just don't know what it's called. This is the sort of thing I'm thinking of, though it may seem a little labour-intensive...
    Radiator Tube Bead Forming - The Garage Journal Board
    Just an idle thought at 12.37AM....
    Edit:- Found this as well, appears to be inserted into the pipe, then the bolt screwed up which pushes the balls against the inner wall...and the tool rotated etc.
    http://www.chicagoconnection.us/images/earls/008ERL.jpg
    Narre Warren South
    Quote Originally Posted by JayBoRover View Post
    I think I also ended up with a Corolla hose for at least one of the hoses. I'll have to have a look in the shed......
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Queensland
    I have used a MACKAY 27EE9K 7087 .One each for the top and bottom.
    Then a cut down Rangie hose for the one on the inlet manifold.
    Narrogin WA
    I
    Thanks for that Keith - any more information on which Range Rover hose to use?
    Cheers Charlie
