Results 1 to 10 of 17
Thread: Low coolant alarm?
    Mar 2012
    morisset
    Low coolant alarm?
    Hi all,
    could you please tell me what type of Low coolant alarm you are running
    in your P38's.
    Could I please also have some installation pic's & advice as I cannot find anything that relate's to our P38's.
    The car in question is a 2001 HSE with 225km's.
    Thank's in advance,
    Steve.
    I have fitted a Little Black Box with a float switch.
    Home
    Installation: http://www.littleblackbox.co.za/Rang...MS_Fitment.pdf
    Contact Jan (The Entertainer) on this forum.
    Feb 2013
    Gosford, NSW, Australia
    Hi
    I have recently researched this and there seem to be a few options;
    1) Late model RR classic cap has an sensor in it.
    2) BMW coolant tank which includes a sensor (check rr.net for details)
    3) BMW sensor fitted to rangie coolant tank.
    4) Little black box or other engine temperature systems.
    5) DIY sensors.
    I like the idea of an engine temperature monitor, but I don't want yet another display and box i need to find somewhere to mount !
    I have decided to go wiht a DIY sensor, so I purchased this kit
    LOW Water Level Alarm 12V Built AND Tested | eBay
    It allows me to add an LED plus a buzzer which can be added to my dash without major mods and without a box to mount somewhere.
    I have a couple of 75mm stainless steel self tappers which i intend to put through the top of the coolant tank. If it is going to leak, better steam than water i figure!
    I will take pics when i do it and let the forum know
    Steve
    Quote Originally Posted by SteveFarmer View Post
    My Little Black Box (LBB ) came with a SS screw for water level detection. It was unreliable so I fitted the float valve.
    One reason I went with the LBB was that it monitored more than water level. The overheat alarm on a P38A is a tiny red light that is almost impossible to see in daylight. I was going to put an audible alarm across that light the next time I have the instrument binnacle out.
    Apr 2012
    Engadine NSW
    I use this one as recommended by Stuart a G Cooper. It works well and self tests on ignition.
    Rob
    LOW Water Level Alarm 12 24V | eBay
    Feb 2013
    Hi,
    I looked at a few float valves, but the plastic ones only seem to be rated to around 80 degrees, plus there was the issue of how to fit it.
    False alarms may be an issue, in which case i may need to add a delay timer as detailed on rr.net
    I intend to put the buzzer just under my dash, and the (very bright) LED somewhere pretty noticeable!
    I don't think hooking it up to the low windscreen washer alarm is such a good idea either.
    Steve
    The temp rating of the float valve doesn't seem to have been an issue - I've had mine for over 5 years.
    The unreliability of the probes seemed to be related to water conductivity as it used a single screw in the tank and the current path was from that to chassis/engine block.
    Feb 2013
    Hi
    It is worth reading this thread
    Coolant Level Sensor
    and the associated ones ;-)
    Steve
    Feb 2013
    Ron,
    I thought maybe there were some more highly rated ones available, there are stainless steel versions i saw.
    The system i got uses 2 screws, so it may be more reliable, I imagine the current path a single screw requires could be a bit iffy !
    Steve
    I see from the RR.net threads that I fitted the LBB IN 2007.
